TBI on EBay
Old Nov 26, 2003 | 05:15 PM
Frik92RS's Avatar
Car: Camaro RS
Engine: L03 305
Transmission: 700R4 Auto
TBI on EBay
Hey I was looking at this TBI on Ebay
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2444657840
and I wanted some opinions on it. I was the high bidder until someone else pushed the price to over $150, is a unit setup like this worth $200+? Thanks.
Old Nov 26, 2003 | 07:58 PM
Bill usn-1's Avatar
Car: IH Scout
Engine: 345 V8 TBI
Transmission: 727
TB upgrade
I think this would be a much better upgrade!! 2 in bores and bolt your pod on this base.
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2443448312
Old Nov 26, 2003 | 11:09 PM
Low C1500's Avatar
Car: 89 Shortbox
Engine: 350 Vortec
The first tbi is probably worth 10hp peak.
Old Nov 26, 2003 | 11:28 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
the first one is overpriced and the second is a holley base, which will need some modifications to work in your car, although its part way done seeing as how they drilled out the wrong way linkage the holley had. IMHO, both are overpriced. The reason *I* believe so is that jsut about all used tbi's are worn around the shaft area and it causes the throttle to stick and bind and jsut generally make things feel sloppy. I wouldnt pay too much money for an improved base if its avoidable.
Old Nov 27, 2003 | 12:04 PM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
The first one is worth $10. For 150-200 you can get a complete used Holley 670 or 454 tbi.
Old Nov 27, 2003 | 10:17 PM
r90camarors's Avatar
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
The only way it took 30 man hours to do that is if the guy was blind. I just got done completing those same mods to my holley, and though it did take a while, it was no where close to 30 hrs, nor is it worth paying that rediculas price, especially for stock bore size.
Old Nov 28, 2003 | 05:40 PM
Z28GEN3's Avatar
Engine: 305TBI
Axle/Gears: B&W 9 Bolt 3.73
i'd have to agree its not worth that amount of money unless you know for a fact what you are getting. so what if it has new seals and gaskets if the bushings for the throttle linkage are worn out then your just wasting money. I'd opt for the 2" holley base, if you have a choice. heck i walked into a junkyard and picked up a used TBI complete for $20 it needed some TLC, before it worked properly.
junior419
Apr 7, 2025 11:35 AM
AmpleUnicorn88
Sep 24, 2015 09:15 AM
Glowsock
Sep 11, 2015 11:09 PM
e3pres
Sep 9, 2015 01:51 PM
Wylecoyote08
Sep 8, 2015 08:26 AM
