Need to beat this !!!
Old Nov 27, 2003 | 08:47 AM
Mc Firebird's Avatar
Car: 1991 Firebird
Engine: LO3 5.0 TBI
Transmission: TH700R4
This is my target, I need to match these times.
Does anyone have a way to determine how much raw power I need to make to take this young upstart ?
Old Nov 27, 2003 | 09:38 AM
Brent's Avatar
Depends on traction and weight.......
If you can get your car to cut better 60' times than his you won't need quite as much power.
I'd bet you'll need around 235hp to trap faster than his 93mph.
Old Nov 29, 2003 | 01:31 AM
Beast5spdGTA's Avatar
Car: 2007 Corvette Z06
Engine: LS7
Transmission: 6 speed
Man, that one run with the 1.98 60' looks like a miricle run. all the others are ~2.5-6 sec
Do a search for my name and "305 dyno numbers".
I ran 14.7 at 93 mph with the stock cam, heads, intake, etc. but you will definately need a torque coverter if it's automatic.
Basically you will need a car with ~3350 lbs w/o you and ~180 rwhp and ~260-270 rwtq. and then a 60' of 2.1x sec.
Old Nov 29, 2003 | 01:38 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
just spray it with about 100hp of the giggly-go
Old Nov 29, 2003 | 10:33 AM
Car: 1991 Firebird
Engine: LO3 5.0 TBI
I thought it might take a bit more HP as I doubt whether a stock 350TPI would run these times and they must be around that HP level.
I have headers / air filter / lt4 cam / performer rpm intake to go onto a 305tbi, and once the damn pocket programmer2 and Romulater eventually get "over the pond" (guess the whole USA shuts down for thanksgiving, happy holidays you all) I am hoping to get near these numbers........ or am i talking myself into an impossible race?
will the standard 305 injectors support this HP level or should i ebay some 350/cop car/big block injectors ?
Old Nov 30, 2003 | 10:29 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
After you are fully tuned you will most likey need larger injectors. You may be able to re use the stock ones if you keep the stock heads. That will limit your power making capabilities with that cam but should keep you in the range of the stockers. A 350 TPI should run way better than those numbers to and should be a mid 14 car all day long. Your data logging will tell you if your injetors are keeping up.
armybyrd
Oct 24, 2015 06:59 AM
beltran89
Theoretical and Street Racing
46
Oct 7, 2015 07:36 PM
Cameeeero
Sep 18, 2015 04:00 PM
86White_T/A305
Aug 17, 2015 12:16 AM
recaro xfire
Jul 16, 2001 08:49 AM
