Towards a more convenient WinALDL cable
Old Dec 11, 2003 | 05:45 PM
Joel Geerling's Avatar
Car: 91 Formula
Engine: 305 TBI
I soldered together one of these cables about a year ago, but it's a pain to shove the wires into the correct pins on the car's OBD I female connector (and get them to stay in place).
I searched around for OBD I male connectors a long time ago and turned up zero.
Has anyone found a source for an OBD I connector that would allow us "finish" our interface cables without naked wires at the car end?
Old Dec 11, 2003 | 06:39 PM
chevypower's Avatar
Car: '89 Formula, '97 Z28, '88 Formula 350
Engine: 305 TBI(LO3)
Transmission: TH700R4(MD8)
What about the cable ends off of a scanner?
Old Dec 11, 2003 | 08:16 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Auto X-Ray cable from Jegs or Summit. Cut/splice into opposite end.
RBob.
Old Dec 11, 2003 | 09:48 PM
jeepguy553's Avatar
Car: 1980 Jeep CJ7
Engine: AMC 360 with GM TBI
Transmission: TF727 set for kill...let's get it on!!!
Or you could try this...get a couple of the pin connectors that are used in the WeatherPak connectors. Crimp/solder them to the wires you have on your ALDL cable and use those to keep the whole thing in the right place.
Old Dec 11, 2003 | 09:53 PM
25THRSS's Avatar
autozone will give you a "key" for your diagnostic ports for free that fits perfect and all you would have to do is cut it in half and solder the wires on.
Old Dec 12, 2003 | 11:32 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Heres what i did. I ended up building a serial port right into the dash so it would get the wires out of the way. I kept knocking them out with my knee.
Old Dec 12, 2003 | 12:11 PM
Z28GEN3's Avatar
Engine: 305TBI
Axle/Gears: B&W 9 Bolt 3.73
dimented24x7
thats cool. nice placement too.
I havent tried my cable yet, but i used coiter pins and soldered them to the wire ends, of course i have to park my car outside my bedroom window to reach my computer.
Old Dec 12, 2003 | 12:22 PM
Car: 91 Formula
Engine: 305 TBI
I know you can use pins or rivets or little metal clips, but I'd like it to be nice, clean, and sturdy - i.e. a plastic connector.
And paying $$ to buy an AutoXray etc. from the parts store doesn't seem like an intelligent way to get a plastic OBD I connector that shouldn't cost more than $5!!
Hasn't anyone else wanted to put a nice connector at the end of their cable? Someone must make/sell them - anyone?
Old Dec 12, 2003 | 12:42 PM
jwscab's Avatar
Engine: Many
Transmission: Quite a few
I took an aldl connector out of another junker at the scrap yard, made up some brass pins that were long enough to go in-between two connectors, and soldered 'em into that one. Now I have a connector that interfaces with the aldl in the cars no problem. I just used some brass stock I had lying around, cut it to length, rounded the corners, pushed em in, and soldered. works great. just another option for anyone that can get to junk cars and take them out. best part is that you could score a handful of them, thow em in with the other stuff you pick up (you are in a junkyard afterall), and the u-pullit yards usually don't even care......my girlfriend wonders why I like the junkyards so much.....hah....
Old Dec 12, 2003 | 12:47 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
i have 2 solutions.
1. get a cheap "scan tool" from walmart... this is nothing more then a cheap plastic casing, and a wire to jump the ALDL pins.
take it apart and solder your wires to that.
2. hook your cable into the back side of the ALDL cable port. run the cable under the dash and end with a serial connector of your choice.... the cable stays in the car, and the computer jsut plugs into the connector when need with a normal serial cable. very similar to what dimented24x7 did... athough you dont have to mount the port where its visible if you dont want to.
Old Dec 12, 2003 | 10:05 PM
azvolfan's Avatar
Car: currently thirdgenless!!!
Dimented,
Love that serial placement. Good clean job. My only questions is, where is the cable connected? And is it connected all the time?
Bill
Old Dec 12, 2003 | 10:57 PM
Car: 88 Camaro SC
Engine: SFI'd 350
I took the pins out of the ALDL connector and soldered in the two wires at the back of the connector and mounted teh 'guts' of the cable in a project box and mounted it under the dash. Its pretty much on all the time. Any time i want to datalog i jsut plug in a serial cable to my laptop into the port and go.
Old Dec 13, 2003 | 09:25 AM
jeepguy553's Avatar
Car: 1980 Jeep CJ7
That IS a cool idea, dimented! DId you solder the capacitor and resistors into the "cable" or do you let the external patch cable take care of that for you?
Note to self...get another DB9 connector for the Jeep dash...
Old Dec 13, 2003 | 11:20 AM
Car: 88 Camaro SC
Engine: SFI'd 350
its all internal to the connector itself. All i do is jsut plug in a run of the mill serial cable.
Old Dec 13, 2003 | 11:48 AM
MechCD's Avatar
Car: '92 Camaro RS, '93 Ranger
Engine: LO3, Vulcan
Transmission: 700R4, M5OD
Axle/Gears: 2.73, 3.45
I have some small nails I filed flat and stick in the right pins. From there I ran a phone cord that connects to my laptop. The phone cord is thin, and can be rolled away easily. The cord usually lives under my center console and gets rolled up under the seat when it isn't in use.
Old Dec 13, 2003 | 02:24 PM
TonyC's Avatar
Car: A Camaro
Engine: Weak
Transmission: Weaker
I just left my cable permenantly attached and I routed it through the dash and the connector sits in the ash tray, so when I want to hook it up, I open the ash tray, get my serial cord and plug it in. Done with it, just close the ash tray.
Tony
Old Dec 14, 2003 | 03:50 PM
seanof30306's Avatar
Car: 1989 Formula WS6
Engine: L03 305 TBI
Axle/Gears: 10 Bolt; 3.42 Posi
is there a place you can buy a pre-made winaldl cable?
Old Dec 22, 2003 | 04:26 AM
Mc Firebird's Avatar
Car: 1991 Firebird
Engine: LO3 5.0 TBI
Seanof30306
I bought some cables from ebay, but note
DO NOT - DO NOT - Buy the expensive MASTACH.COM cable, I have had two and spent at least one month sending e-mails back and forward to the guy that makes them in Poland. BOTH MASTACH CABLES DID NOT WORK.
I then ordered a simpler version from GLEN MOVEY on arrowsp@qnis.net it was $9 (again on ebay) and it worked first time and still works everytime !!!!.
The end connectors that go into the ALDL port are a nice long fit as well, so they stay in the port quite well.
Old Dec 22, 2003 | 11:59 AM
Engine: L03 305 TBI
Originally posted by Mc Firebird
Seanof30306
thanks dude,
i emailed him a few minutes ago.
Z28/ZR1
Oct 23, 2015 01:04 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
