well my fuel line is leaking so im going bradide stainless steel so
Car: Black 89 Formula
Engine: ??????????
Transmission: ??????????
Anybody know all the part numbers for the stainless steel lines and adapters for the tbi fuel line and return line i need the adapter from the hard metal line that connects to the rubber line.
Car: 96 Silverado/99 Suburban
Engine: 700 cubic inches of 'Muican Awesome
Transmission: 4L80/4L60
Axle/Gears: Chunky/Clunky
That and you can also go into your local GM parts shop and they will actually print out a page with all the numbers on it for you. They did it for me for a few things and they don't charge ya a penny...
Bruce (90RS305)
Bruce (90RS305)
From: "When the going gets weird, the weird turn pro." -RIPHST
Car: 1991 RS
Engine: 383TBI Fastburns and 2"TB
Transmission: T56 held up by Spohnstuff
I covered the braided stainless steel fuel line setup a while ago. It is here: https://www.thirdgen.org/techbb2/sho...58#post1443458
S-D
S-D
Engine: ??????????
good job but my RUBBER FUEL lines are leaking not my metal ones the rubber ones are also going to get the bradided treatment.
Car: 1991 RS
Re: well my fuel line is leaking so im going bradide stainless steel so
Also, capitalization and punctuation help avoid confusion.
S-D
Your better off getting replacement rubber lines from a dealer or equivelent rather than try to hunt down metric adapters for the flexable lines. The metric adapters are custom order , if you intend to do it, you should just call holley or aeroquip directly.
Car: check
Engine: check
Transmission: check
9894DBH Female 14mm x 1.5" to -6: Fuel Injection Female "O" Ring Seal
9894DBJ Female 16mm x 1.5" to -6: Fuel Injection Female "O" Ring Seal
http://www.holley.com/HiOctn/ProdLin...A/9894DBH.html
Then whatever -6 AN hose ends and hose of your choice.
RBob.
Car: 1992 Camaro RS
Engine: 383 w/Holley Stealth Ram
Transmission: Pro-built 700R4
go to this guys web page he already did the hard work for you in finding all the parts .
http://z28boy.cz28.com/
Hope this helps
Nick
Hope this helps
Nick
Engine: ??????????
Originally posted by RBob
Two each of the following:
RBob.
RBob.
theshackle
Mar 5, 2017 06:37 PM
AkDrifted
Aug 17, 2015 07:45 PM
