Removing Backing Plate Off Hood?
Old Jan 17, 2004 | 04:01 PM
LedZep's Avatar
Car: 1990 Formula Firebird
Engine: 305TBI w/ Functional Sport Hood CAI
Axle/Gears: SLP Posi and 3.23 Gears
I just removed my backing plate off my powerbuldge hood and its going to rain here in a bout 3 hours, will I have any problems with water after doing this? And if you have done this and have had no problems how long has your hood been like that? Thanks for any help
Old Jan 17, 2004 | 04:47 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
I never had any problems with my Camaro by having the cowl induction scoop open year-round. You could occasionaly see raindrops or snowflakes being sucked in through the opening.
I did have a couple drain holes drilled into the base of the air cleaner housing to let out any water that would accumulate.
Old Jan 17, 2004 | 05:34 PM
Formula&Z28Toys's Avatar
When you remove the backing from the cowl it lets water in. This cause two problems for me. #1 water ran into my Xstream Airlid and down my tbi into my motor... I had to pull every plug and crank it to get the water out. #2 it kept my starter soaked and eventually burnt it out. If you don't have a K&N Airlid, and don't mind replacing starters... leave it off.
Colin
Old Jan 17, 2004 | 10:32 PM
LedZep's Avatar
Any other opinions? I have never heard of anyone having problems till now...so any opinions would be helpful.
Old Jan 18, 2004 | 03:59 PM
LedZep's Avatar
I was thinking to prevent water from getting in couldnt I put a screen off a window in the buldge and paint it black and would that not prevent most water from going in and still let air in.
Old Jan 18, 2004 | 05:34 PM
That wouldn't keep water out of there anymore than it would on a window....
Old Jan 18, 2004 | 05:36 PM
LedZep's Avatar
But a screen does keep water out of a window.... thats the point..
Old Jan 18, 2004 | 05:40 PM
Uhm... go get out your hose, spray it at your screen door on your house with someone standing behind it. I have a feeling the person will get wet. Thats the point. It's not waterproof, and water will get in.
Old Jan 18, 2004 | 06:04 PM
LedZep's Avatar
I am not planning on spraying a water hose into my hood.. and It doesnt rain that much here. Also if it is going to rain for a long period of time ill just put the plate back on.
Old Jan 18, 2004 | 06:13 PM
Then you have your answer. I was going to ask if I could buy your backing plate from you since my car doesn't have one and has cost me a starter and the aggravation of having to clear my motor of water ingestion. To me its not worth the headache for something that probably only delivers a couple hp, but to each his own.
Old Jan 18, 2004 | 07:24 PM
LedZep's Avatar
Ok after hearing a few opinions from various people I decided to put it back on and im in the process of looking for the functional induction set up off an early 80's Bird. Anyone know where I can get one? I posted an ad in classifieds. Or anyone installed this and have an opinion? Also how much would a fair price be? Thanks for any help.
Old Jan 18, 2004 | 10:02 PM
Third Gen Resource or Hawks should have it. It's 82-83 Trans Am Functional Cowl setup. Hope this helps....
Old Jan 19, 2004 | 01:43 AM
http://www.hioutput.com/tech/air.html
Eric-86sc
Apr 3, 2016 03:52 PM
sailtexas186548
Jan 19, 2016 12:21 PM
sailtexas186548
Brakes
Aug 13, 2015 11:47 AM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
3rdgenparts
Aug 8, 2015 07:09 PM
