engine just flat out gives up
Old Jan 28, 2004 | 05:20 PM
c4boom's Avatar
Car: 87 iroc and 88 k2500 tbi truck
Engine: l98 and lo5
Transmission: 700 r4's babby
ok when i am driving down the road some times the motor will just start to loose power and if i get on it, it will stall. it is like there is no fuel or some thing. it is so bad some times i can not get up small hills and can not go faster than 35-40. hear is the kicker if i shift into natural and shut it down and start it right back up it will run fine. where should i start to look fuel filter is brand new.
Old Jan 28, 2004 | 05:22 PM
Fairly Strange's Avatar
Car: '89 Formula
Engine: 305 TBI
fuel pump.
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: engine just flat out gives up
Does it sputter or just not go? Can you still rev it or is it rpm limited because of the problem. It sounds like you have a dying fuel pump or relay but it could be a number of things. Check out your injecotr spray. It is nice and even or does it look patchy and hit and miss?
Old Jan 28, 2004 | 06:50 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
I'd try to put a fuel pressure gauge on it, but my bet is bad fuel pump. Replace with high performance one.
Old Jan 28, 2004 | 09:37 PM
BadBlue91RS's Avatar
Car: 1991 Camaro RS
Engine: Briggs & Straton
Transmission: Centrifical Clutch
Re: Re: engine just flat out gives up
If it has limited revving capability, it may be the Cat.
Old Jan 28, 2004 | 11:15 PM
c4boom's Avatar
Engine: l98 and lo5
no it is not rpm limeted. dose not sputer or any thing acts like a choke is stuck on a carbed car.
Old Jan 29, 2004 | 01:03 AM
steve8586iroc's Avatar
This may not be your problem but my car did something very simular. I happened to be looking at the volt guage and it was below 10v. Turned out to be a bad alternator. I was glad to be able to get the car home, and as you said it would idle ok but would not pull the car at all.
Steve
theurge
Aug 21, 2015 12:46 PM
mustangman65_79
Aug 13, 2015 07:36 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Armored91Camaro
Aug 12, 2015 09:41 AM
anesthes
Aug 8, 2015 09:37 PM
