What the easiest way to check timing on my RS?
Old Feb 4, 2004 | 04:17 PM
GASGZLR's Avatar
Car: 1991 Camaro Z28 5.7 G92
Engine: L98 Tuned Port Injection
Transmission: TH700R4
Axle/Gears: 3.23 Posi G80
I am doing a tune up on my new 89 RS and I know that the timing marker is at the 12 oclock position, and all the stuff about bypassing the computer with the tan wire. How hard is it going to be to check and adjust the timing if I can't see the mark? Will I have to look through the water pump gap from the top?
Old Feb 4, 2004 | 04:32 PM
BronYrAur's Avatar
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
You need to disconnect the wire, get a timing light and point it down at the mark and look where it is on the marker.
Old Feb 4, 2004 | 04:38 PM
GASGZLR's Avatar
I know how to check the timing on a car with my timing light but I am talking about the line-of-sight to the balancer, cause on my 350 the marks are in the normal spot--->the 2 ocolck position and that makes the marks easy to read.
Old Feb 4, 2004 | 05:27 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I have to lean way into the engine bay and point the light straight down behind the water pump. It is trickey to do espcially if you keep getting your timing gun wires close to the belt. It is almost better to have two people to do this. One to read the light and the other to work the distributor.
Old Feb 5, 2004 | 09:29 AM
BronYrAur's Avatar
Engine: 305 TBI
That's what I do too. I couldn't quite tell what you were looking for with your question at first.
specialized
Jun 18, 2022 09:26 AM
Infested
May 22, 2018 11:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
justin57
Aug 20, 2015 07:05 PM
Fronzizzle
Aug 17, 2015 02:52 PM
