Ported crossfire, tbi , or tpi
Old Feb 4, 2004 | 07:47 PM
Blankmantn's Avatar
Car: 84 vette
Here is what I have built so far: 4 bolt main 350 block, decked and bored .060 over, 882 shaved heads( I know not the best), double roller timing, 230/230 cam. Should I use my ported crossfire intake with 2in tb's, or a 88 iroc tpi system, or an aluminum intake with a 454 tbi on it? Thanks for your help! Oh, this is for an 84 vette.
Old Feb 5, 2004 | 08:27 AM
kdrolt's Avatar
Car: 93 GM300 platforms
Engine: LO3, LO5
Transmission: MD8 x2
IMO with that engine & cam, you should use an intake manifold that will move a lot of air -- so I suggest a carb-style intake manifold and the 454 TBI unit.
The ported CF essentially matches the stock TPI, and the stock TPI is also somewhat flow restricted (though it's great in a heavy car or truck because of the torque production at mid speeds). So these two are both flow-limited, and your cam choice is set for higher speeds. That's why I suggest a conventional manifold + the big TBI unit. This choice is probably the least expensive too.
Item: you'll need custom ECM tuning to get everything dialed in, and you'll also need a fuel pump that can deliver enough volume.
Old Feb 5, 2004 | 12:32 PM
Ronny's Avatar
yup that is my set up to date. just need to install 226/234 @.05 and add the 454 dual TB and the remote FP gauge...
Old Feb 5, 2004 | 03:42 PM
CtRw's Avatar
Car: 1983 Camaro Z-28
Would you be interested in selling that crossfire intake? let me know with a pm or e-mail.
Old Feb 5, 2004 | 09:49 PM
Blankmantn's Avatar
Car: 84 vette
Thats kinda the way I was leaning. Does anyone have a preference to which intake? I found a GM 10105143 aluminum intake with a 350 tbi, fuel lines, sensors, and throttle cable for $75.00 in a junk yard. Do you think this would be a good start?
Thanks!
Old Feb 6, 2004 | 01:01 AM
steve8586iroc's Avatar
If you don't want to mod the hood you will have to check your clearances. Don't get a manifold the will make the tb sit too high because you will need an adapter, unless you use the Holley projection manifold. A good carb intake you might want to look at is the Wieand Stealth single plane intake. Happy hunting.
Steve
Old Feb 11, 2004 | 01:55 AM
wills83z28cfi's Avatar
Car: 07 Silverado
Engine: 5.3L V8, flexfuel E85
Transmission: 4spd. Auto
Axle/Gears: 3.73 locking diff.
Hey Blankmantn, could you please keep us updated on your mod, how things turn out, and what you decide to use? I am still trying to decided wether or not to get rid of the cross-fire for something else. Want to build a motor with around 350-400hp, and 400+tq. Some people say keep the cf and port it, etc. Some say to do what your doing, others say go to carb or tpi. I don't know much about cars or engines, so I want to try to get it right the first time. Just can't make up my mind yet. So I need all of the input I can get. Oh, plus I need to take into account that I live in CA, smog rules suck out here, the visual inspections are what can make or break you. My camaro is my daily driver too. Thanks for any help you can give me. :hail:
Old Feb 27, 2017 | 08:49 AM
fudog13's Avatar
Re: Ported crossfire, tbi , or tpi
Hello I'm new to the Group I need to ask a question,I have a 1989 camaro rs 305 5.0 e motor tbi,The intake manifold has a vacum leak so it needs to come of and new gaskets replaced.I can't work on my car any more due to a back injury so I want a nice painted manifold going back on my car,so I was looking to get a to buy a spare Manifold so I can get it clean then have it put back on.I found a manifold The Part # is 10105143 it's a stock intake manifold Any info would be greatly appreciated.Fudog .
Old Feb 27, 2017 | 09:58 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Wow dead thread! , Since the 10105143 is off a tbi f-body it will work.
Fast355
Dec 2, 2016 06:33 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
Sanjay
Aug 12, 2015 03:41 PM
mx127
Aug 10, 2015 08:13 AM
3rdgenparts
Aug 6, 2015 09:03 AM
