May have goofed here...Edelbrock intake
I just got some parts in that I ordered and had asked for an Edelbrock vortec intake to go along with the vortec heads that I also ordered.The intake that I got is part #3704 Performer TBI.Upon further review it looks as if this is a direct oem replacement and not a big upgrade.Will this intake even fit these heads?Would it be worth keeping? As I look at the Jegs website it lists a "vortec" Performer AND a "vortec performer RPM.It says they both are for 4 barrel carbs...how would this work for TBI?Like i said...I have the vortec heads and a new spring kit to be able to run the Comp 276HR-14, Comp Controlled, Hyd Roller, 276/290-220/230-.510/.510-114.I'm also getting headers and a good exhaust to go with it.I had planned on keeping my ultimate modded tbi so I really don't know which intake is right.Am I on the right track here?
92 305 rs tbi
92 305 rs tbi
ok...so I'm a little slow..lol...I've come to conclusion the tbi performer won't work with the vortec heads after physically mating them together.I guess I need at least the Performer RPM Vortec.My next question if anyone knows is...Will I be able to close my stock hood using the vortec intake with a tbi adapter plate?Where could I get one?Thanks
92 rs 350 tbi
92 rs 350 tbi
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
I doubt it. I have a '71 Camaro with the Vortec heads and a Performer intake, and I have to use a 1.5" air cleaner to close the hood.
The RPM is gonna be a little taller. Not saying it can't be done, but it'll be tight.
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
Is that going on a 305? I think that cam will be way to big. I run it in my 383, an it pulls to the max ecm rpm of 6,400rpm, that is with a 2" 2bbl tbi. Also, I may be wrong, but you may need to do more work than just springs to make those heads capable of handling that lift.
This is just my suggestion, but if you plan on keeping the 305 and using the heads and cam:
Have the heads milled to 58cc to keep compression
Look into a single plane manifold
Consider a holley 670tbi with 65pph injectors
I run the performer rpm airgap, and like it. It did wonders over the performer I had on there, and I consider the performer rpm intakes to be the best dual planes for the vortecs. But I really think single plane is the way to go for high rpm engines. Also, with the adapter plate, my stock hood would not clear.
Car: 1989 Formula WS6
Engine: L03 305 TBI
Axle/Gears: 10 Bolt; 3.42 Posi
i don't think we've ever gotten a definitive answer on how much you have to mill a set of vortecs to get from 64cc to 58cc. has anyone actually done this and ccd the heads afterwards? when this comes up, people will often state their opinion, or the opinion of a machinist they've talked to, but i don't think i've seen anyone saying they've actually done it.
also, when you mill vortecs to 58 ccs, won't that greate valvetrain geometry issues?
there is a Vortec TBI manifold, by the way, but it isn't an Edelbrock, it's made by GM. goes for $309.99. probably better and cheaper with the RPM, but just thought I'd throw that out there....
Car: 91 RS
I installed the Vortec's on mine without any milling....
A big increase in power. I doubt that you could tell any diff with a little more compression after milling.
My 2cents.
My 2cents.
Engine: LO3;383tpi
Milling the heads to 58cc keeps the compression at 9.3:1 given you use a stock thickness head gasket. I'm not too sure what leaving them at 64cc lowers the compression to, but using a thinner head gasket will bring the compression back up a little.
Milling the heads should not create an issue.
Hi Dm91rs
My 2cents.
My 2cents.
92 305 rs tbi
Car: 91 RS
bloyurdoorsoff
I made an adapter plate on a mill and it on top of the RPM intake with a taller LO5 breather just does miss the top of the hood with no liner on it.
I burn my own chips. I am not one to give advice on that as I'm still a beginner in tuning but the chip programming and burning part is eazy.
This is just my advice but I would go with a mild cam to begin with.
Car: 91 RS
bloyurdoorsoff
I burn my own chips and it will some tuning. I am not one to give advice on that as I'm still a beginner in tuning but the chip programming and burning part is eazy.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Car: '90 RS
Engine: 377 LSX
Originally posted by Ronny
what is the issue with GM vortec intake? is it a truck application?
Car: 70 Nova SS
Transmission: TH350
as far as the intake goes I am running Edelbrock Performer Carb manifold with the holley TBI adaptor plate with a 2.75 open element. I ripped out all of that liner stuff too. Its a tight fight but it closes.
Hope this might help
My 2cents.
My 2cents.
I pulled my heads (heavily home ported 416s) to have some guide work done and at the same time I had them milled and went from 8.8:1 cr to about 10.
The difference in mid range torque was insane and dropped my et by a little over a tenth on average, not adjusting for traction problems... maybe almost 2 tenths on a 13.6 car thats alot more of a difference than a tenth in a 15s car
Ill bet if you milled your heads youd really like the gain. Compression is great.
Car: 91 RS
The Vortec's are coming off the 305 to go on a 350 I'm building. I will be replacing the Vortec's with a set of 081's that I've ported and just have to mill down the guides, install new springs and seals and maybe install new valves. The 305 still runs strong but I'm just going to use it until the 350's ready and then the 305 will get freshened up and installed in my S10.
Later.....
Darrell
jerflash
Sep 24, 2015 03:11 PM
toronto formula
Sep 10, 2015 07:31 AM
e3pres
Sep 9, 2015 01:51 PM
