Hissing/Sucking sound
Recently I installed an open element just to trash the ugly stock one. There was no sensor connected to the stock air filter assembly, this may be irrelevant. Sometimes, mainly when the car is cold, I get a hissing/sucking sound, this also sometimes happens when I get on the gas. I plugged the vacuum line with a pencil and removed the spacer on the intake. Any ideas to what this hissing sound may be? I'm guessing that I'm just hearing the throttle opening up.
Car: 96 Silverado/99 Suburban
Engine: 700 cubic inches of 'Muican Awesome
Transmission: 4L80/4L60
Axle/Gears: Chunky/Clunky
close you mouth and plug one nostril and breath. Then open you mouth as wide as you can and breath...Notice the sound difference? Yeah thats kinda the difference between our awesomely designed stock TBI intakes and the open element.
Bruce (90RS305)
Bruce (90RS305)
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
The stock air box does alot to silence that. Most of the hissing is the air rushing past the IAC at cold start and when the throttle is applied. The stock airbox is a decent match to a stock tbi engine. Doesnt need much air and is pretty well met by a single snorkleIf you dont like the noise you can always put it back on. My friend ran one of those on a ZZ4 with a modded Q-Jet and was able to get some decent numbers out of it, although teh dual snorkle worked much better.
Intakes are designed from the factory to quiet the flow of the incoming air. Anyone see the intake for a 5.3L vortec truck engine? You know how they have that huge horn shaped chunk of plastic coming off of the intake ducting? Well, that chunk is there to muffle the sound of rushing air. Personally, i dont like it. I rather enjoy the sound of my car sucking in air... :lala:
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
yup. like they said.. its the air sucking in.
the first performance motor i ever built was a 400sbc that i poured every penny my high school butt could earn.
sound wise, i got more of a thrill out of hearing the 2ndarys open and suck in the air, then the exhaust note..... to this day that suck-whoosh that happens when you snap the 2ndarys open gets me giddy.
Car: 91 1500 ex-cab pickup
Engine: 350 vortec
Transmission: 5-speed
It the injectors are getting old they well make a hissing sound when cold and when you get on it my truck did that swich to newer injectors and know don't hear it as much sounded cool at
high r's.
high r's.
Car: 91 Camaro Vert
high r's.
high r's.
1. thats what he just changed... and it is ALOT louder when you do that....
2. mine does it and it has brand new injectors.... everyone i know, regardless of induction that has a open element has that sound. carbstyle multipoint EFI, carb, and TBI with open elements make that sound.
the injectors are more of a tick anyway... not a sucking sound.
Car: 91 Camaro Vert
Originally posted by joshwilson3
I have an open element. What type and size push in filter have you all used for the passenger side crankcase? I'm having trouble finding one. As I don't think acdelco or napa make a push in filter, just no name brands. Also, do you guys know the OD of the size gasket the filter needs to have?
im just using a no name, chrome push in breather that i got from the "cheap chrome stuff" isle in my local auto store..
any "standard" push in breather will work.. justpull the tube out and shove it in. if you want to have it look somewhat stock, get a barbed fitting, and a pipe or adapter that just slips into the valve cover hole.
stick some PCV/Fuel (not vac line, not regular rubber line) hose on the barb, and knock out the hole under the open element... put a 2nd fitting on there, and connect the hose.
if you do it nice, it can look somewhat stock, and is pretty small... instead of getting the filtered air from its own filter, it gets filtered by the engine filter... like the stock setup.
but i think thats alot of work for nothing.. i got the $6 one and im happy with it :lala:
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Car: 91 Camaro Vert
just for the heck of it.. heres my cheezy breather:
http://josh.swoca.net/board/mrdude/newpics/IM000118.JPG
im posting a link because its pretty big..
and ignore the dust look..... this was taken in a dark garage and the flash made it look filthy... it actually doesnt look that bad under normal light..
Car: '90 RS
Engine: 377 LSX
What exactly did you use for yours. It is kinda hard to see in the pic.
Car: 91 Camaro Vert
Originally posted by ShiftyCapone
Sure it isn't.........JK...
just a regular plain old generic valve cover breather.
its just a push in breather.
you pull out the tube
you push in the breather.
heres a pic of the first similar style valve cover breather that i could find on a Google image search
Car: '90 RS
Engine: 377 LSX
Car: 91 Camaro Vert
That looks pretty good. Now that my AIR is out of the way and my heater valve delete will be around the corner I will actually have room to put a breather. Before it was to cramped and would not allow and breather with a larger than 2" diameter to fit.
you just have to wiggle everything out of the way first.
