Ultimate TBI questions
Car: 1992 Camaro RS 25th Aniversarry Edition
Transmission: TH-700-R4
Axle/Gears: 10 bolt with 3.23's and SLP Posi.
i would like someone to post pics of their TBI units after performing the Ultimate TBI mods and how it improved their performance. also what kinda times can i expect to see after i do the entire Ultimate TBI upgrades on a other wise stock motor and tranny with a 3.23 posi rear.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Well I don't know if you are going to see any real differnece but it all adds up. it will help you get evey last cfm or air into that stock TBI unit. Some have seen track improvements and others just do it for the sake of a few more cfm's. Here is a pic on mine. It is a lot smoother now but I took this pic before I hit it with some sand paper to smooth it all out.
any pics of what im suppose to do with the Throttle blade?
Car: '90 RS
Engine: 377 LSX
how much a seat-o-pants difference did it have from doing what you did. did you do the injector pod spacer? if so some pics of that woudl be nice also.
Car: '90 RS
Engine: 377 LSX
Car: 89 Camaro RS
Engine: 350 carbed now
Transmission: World Class T5
Axle/Gears: Peg Leg w/ 3.73's
Your not going to see a big seat in the pants difference from it but every little bit helps. If you havent installed a open element filter I would install that and do the ultimate tbi mods at the same time then you will see a seat in the pants difference. I noticed a difference just by doing the open element, so add the ultimate tbi mods and youll probably knock off a tenth or so.
Car: 93 GM300 platforms
Engine: LO3, LO5
Transmission: MD8 x2
As discussed in other threads, the Ultimate mods (rounding the bore leading edges, thinning the throttle shaft) should result in 10% flow improvement (approx 5% for each mod). Since the small 2-bore Rochester TBI flows around 540 cfm, then these mods will result in a gain of around 50 cfm. In terms of power, if you were flowing around 500 cfm (that means if you had the right mods AND had them tuned properly) then you'd have around 300 hp at the flywheel.... so the ultimate mods would gain you 10% extra flow, and thereby 10% extra power (or 30 hp) if you had the ECM retuned to accomodate the extra flow.
The SOTP gains will be much tougher to observe, mostly because of the lack of tuning.
also am i going to need a Drop or Non-Drop base for my Open Element?
Car: '90 RS
Engine: 377 LSX
