Help....
Car: 92 RS
Engine: 5.0 L03
Help....
Everytime i'm gonna start my car it always takes about 5-10 secs. to start... could it be fuel pump or relay. I already put a relaly in but it worked only for like 2 days and then it went back to the same thing... pls don't tell me i need a new fuel pump... thas a bisssch to change.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
It could be your oil sending unit. In a nut shell if it does not see oil pressure right away it will delay the fuel from starting the car. After a few seconds of cranking you build a little pressure and it will fire.
Car: '89 Formula
Engine: 305 TBI
Sorry...can't help but chuckle.....
...any of you guys ever drive a carbed car?
Put those seconds into minutes, and you'd have it about right.....IF you can keep it running after it starts!
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
Car: '90 RS
Engine: 377 LSX
Car: 92 RS
Engine: 5.0 L03
hey capone... changed it, went and bought a new one and still have the same prob... any other suggestions. My dad is a mechanic (for about 35yrs.) and he is tellin me is the module... there is a camaro place in san jose called "POOR SALVAGE" is all camaros every year made... and i'm considerin takin a trip up there and gettin a new module unless someone can help me figure out the problem. thanx for any suggestions...
PS: for all u carb guys DAMN... wouldn't wanna be ya', my prayers go out for y'all.
Car: '90 RS
Engine: 377 LSX
Car: 92 RS
Engine: 5.0 L03
yeah, the sending unit... i've already done all the little things that need to be done... but still the thing won't start, the best i've ever done was that fuel relay, started up quick even in the morning when it was freezin cold...i even called a local dealership to ask about the computer prom and they no longer make the prom for my car... so i'm a little stuck, but not given up yet, i just don't wanna spend more cash for another starter.
Car: '90 RS
Engine: 377 LSX
Car: 92 RS
Engine: 5.0 L03
like i said i've replaced everything... coil, cap, rotor, plugs, wires etc... the starter went out on me about 3 months ago, i'm assuming cuz i sit there crankin it for 5-10secs everytime i'm gonna start the car and i have a feelin is gonna go out on me again. i know the starter is not the problem nor has anything to do with the ignition in general... so i'm leanin towards the module or a fuel pump. but i'll try to prime the pump next time i go and start it... thanx again.
PS: now i got an primary exhaust leak, is gettin loud too... good thing is the drivers side, i guess i'll be spendin this weekend dealin wit this... oh well
LVZ2881
Nov 21, 2005 01:11 PM
