Air Cleaner Lid
Old Mar 2, 2004 | 11:06 PM
ron_firebird_91's Avatar
Car: 91 Firebird
Engine: 350 tbi
Air Cleaner Lid
Hi guys I know that I am going to have hood clearance problems because i have a spacing in my air cleaner (i used a different k&n filter to raise up the lid) and i dont want to lose the extra flow when i puton my new manifold and spacer so i was wondering if anyone was using any of those hi-flow lids like the k&n extreme lid thingy. If so does it work fairly well? Where did you gets yours from and what size? Thanks, Ron.
Old Mar 2, 2004 | 11:24 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Air Cleaner Lid
Waht intake are you going with. I have a 14x3 K&N open element with the extreem lid in combination with a .5" TBI spacer and edlebrock TBI intake. All together I am about .75" taller than the stock height and I can still close my stock hood. It is very close and my wing nut presses into the insulation under the hood but it still closes. I got all of my filter stuff through jegs and summit racing.
Old Mar 2, 2004 | 11:32 PM
Car: 91 Firebird
Engine: 350 tbi
I am getting the edelbrock manifold. It should be on its way I bought it on here. I think the part number was 3704 and he is including the spacer he had on it some im bot sure what size but thats exactly what i am looking for. So a 14x3 and an extreme lid? Cool this should work out just right. Also what do you think of the manifold? Did you notice a difference? I am hoping I will because im doing a spacer, manifold, and the air cleaner assembly probably all at once. Thanks, Ron
Old Mar 2, 2004 | 11:43 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Well you won't notice much from either with the stock heads and cam. The stock intake can support the stock heads and cam. You will see a little better top end but nothing to go crazy over. It is a very good intake, but it responds better with major internal upgrades. The spacer is a waste and I would not run it unless you have a drop base air cleaner that will not clear your distributor. The edlebrock TBI intake is .25" taller than stock. If the TBI spacer that you have is bigger then .5" I would not run it. Plus that intake has a pretty good plenum size that really doesn't need the aid of a spacer.
Old Mar 3, 2004 | 10:35 AM
Ronny's Avatar
i used the edelbrock elite air cleaner. it is oval so clears the throttle shaft nicely. no spacer. it is 3 inch and injector pod is 2.75 inch. other AC needed spacer to clear linkage. with 1/2 inch adapter it should clear my hood.
Old Mar 3, 2004 | 05:14 PM
TonyC's Avatar
Car: A Camaro
Engine: Weak
Transmission: Weaker
I was running the 3704 with a .5" spacer (nitrous plate) and a 14x3" filter and it fit fine. I don't see how the Extreme Lid would be much help since it'll pretty much be hitting the hood lining.
Old Mar 3, 2004 | 07:08 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
I have the same set-up now but my .5" spacer is not a nitrous plate. I don't have any clearance problems either. I only have the extreem lid for looks only. When the hood is shut it is rendered useless and is choked off by the hood insulation. I did not like the look of the cheap chrome lid that came with the open element.
Old Mar 3, 2004 | 09:21 PM
TonyC's Avatar
Car: A Camaro
Engine: Weak
Yeah it definately looks real nice on your engine Shifty!
Old Mar 4, 2004 | 09:00 AM
Ronny's Avatar
wait till i post photo of the billet aluminum Elite Edel AC !
Old Mar 4, 2004 | 09:27 AM
MY-92-RS's Avatar
Car: 92 CAMARO RALLY SPORT
Engine: 383 sbc w/250 shot of nitrous
Transmission: AMERICAN POWERTRAIN- EXTREME TKX
Axle/Gears: STRANGE ENG. 12 BOLT 3:90 SPOOL
https://www.thirdgen.org/techbb2/sho...5&pagenumber=2[/URL]
I put one on last year looks good , when I put on the cowl hood it should get more air
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
edoff13
Sep 11, 2015 03:55 AM
SG91camaro
Sep 5, 2015 10:27 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
