heads
Car: camaro
Engine: mighty 305
Transmission: mighty 700r
go with l98 heads from a camaro (64cc combustion chamber) with lt1 cam and maybe 1.6rr.... Most tell me the heads wouldnt be worth it.
not trying to hijack his thread just throwing an idea out to be debated until he brings up his ideas
Shawn
Shawn
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
the problem is with 64cc chambers, you compresion ratio takes a pretty seroious hit. the other thing to be concerened with is the valve sizing/spacing. most 350 performance heads have large valves hat will not clear the tiny bore of the 305.
l98 heads have basicly the same port design as the 416 305 castings do, only real diffrence is CC size. the 416's also respond VERY well to porting.
Car: 1990 Camaro RS
factory used .015" shim gaskets.
with everything the same, the diffrence of 6cc on a 305 would drop you from 9.3:1 to about 8.65:1
Car: 91' Camaro
Engine: Carbed 305
Transmission: 5-Speed Manual
hm, do you know how much loss in hp that would be?
btw, does someone know the piston down bore @ tdc from a 91' 305?
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Car: 2002 Z28
you could also try 081 305 TPI centerbolt heads. With some porting they should flow pretty good. Also, you could always have 350 heads milled to retain some compression
Car: 89 RS
Engine: lo3
Transmission: 700R4 w/ B&M shift improver
Axle/Gears: 3.27 9-bolt posi
I'd vote for the milling if you really want 350 heads on the 305.
9.3 to 8.65 is quite a drop. Anyone know if the 350 heads flow that much better than the 305's?
-chuck
-chuck
Car: 1990 Camaro RS
valve changes are not a big deal, the port casting between the 416's and the l98's is the same. if you ned the head that much, you will likely have to have your intake manifold done also. keep that in mind.
Car: '90 RS
Engine: 377 LSX
The Dyno2000 Software needs the Piston down bore to calculate the compression ratio.
Car: 92 rs
Engine: 305tbi
Transmission: 4l60e
the heads i picked up are 14102193 heard they are from 350 tbi swivel port heads i do plan on doing small port work to the intake and exhaust would it be possible for me to get the heads milled so much that my compression would go up to say 9.5 1 and does anyone know the specs on these heads compared to the stock heads?
Car: 1990 Camaro RS
i think it is .030" deck height (probably varies from the factory a little" but don't we also have dished pistons?
Car: '90 RS
Engine: 377 LSX
Car: 1991 RS
Engine: 305 TBI
Transmission: auto
How much lift will the 416 heads support?
I have an LT1 cam, and the 416's I'm getting ready to start protiing, just curious if I could go with more lift.
Thanks Scoty
Thanks Scoty
Car: Black 89 Formula
Engine: ??????????
Transmission: ??????????
dont mean to jack your post but i need heads for my car and ive got 300 bucks to do it.anyone know.its the 305 tbi i got and i got a LT1 cam waiting so if the heads had the springs and 3angle valve job that would be great.
Car: '90 RS
Engine: 377 LSX
Thanks Scoty
Thanks Scoty
https://www.thirdgen.org/techbb2/sho...hreadid=227281
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
