air flow enhancer
Old Mar 4, 2004 | 11:14 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
air flow enhancer
anyone have anything to do with this?
http://www.cfm-tech.com/catalog/air_...uck_549430.htm
how well does it work? and most of all, DOES it even work?
Old Mar 4, 2004 | 11:16 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
I dont think an air horn would work well with the tbi. The injector pod sits smack dab in the middle and blocks the flow. Better for carb use only.
Old Mar 5, 2004 | 05:09 AM
chevypower's Avatar
Car: '89 Formula, '97 Z28, '88 Formula 350
Engine: 305 TBI(LO3)
Transmission: TH700R4(MD8)
JEG's & Summit Racing sell the same part, just made by someone else. IMO there better & cheaper than the one you were looking at.
Old Mar 5, 2004 | 08:51 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
They are better suited for carb. It really shrounds the side of the TBI and that is where we get all of our air. With that in place the air has to come from above the injector pod that is smack dab in the way.
Old Mar 8, 2004 | 08:56 PM
chevypower's Avatar
Hypertech is the other company. They say there for trucks only. It may fit with a cowl hood though? Don't know about HP, I've never seen anyone with one.
Old Mar 9, 2004 | 04:31 AM
90RS305's Avatar
Car: 96 Silverado/99 Suburban
Engine: 700 cubic inches of 'Muican Awesome
Transmission: 4L80/4L60
Axle/Gears: Chunky/Clunky
From the looks of it a simple Open Element will work LOADS better than that. Do the ultimate TBI mods and you just gained the same power if not more, AND saved some $$ (IMHO)
Bruce (90RS305)
Old May 25, 2004 | 02:28 PM
Gunny Highway's Avatar
Car: 91 RS
Engine: 350 TBI
Isn't the Hypertech piece the one used recently in Chevy High Performance and Car Craft on those TBI trucks of theirs that put 8 HP and 8 lb/ft across the entire RPM band?
Old May 25, 2004 | 02:40 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Yea it is. I think they sadi they saw 5hp gain on their 305 TBI truck project. I can't say though if their numbers are a plug or not for hypertech. Their 5hp gain could have also been a result of something else.
Old May 25, 2004 | 03:00 PM
Car: 91 RS
Engine: 350 TBI
Check out the Car Craft article. They clearly state how they where unimpressed with it and didn't think it had a chance, but were suprised by the 8 HP and 8 lb/ft across the entire band. . . however they do have a 350 in theirs.
. . . but come to think of it, you NEVER see a car mag criticize a product. So why do I even buy them if they won't give me an honest write up on a product?
Old May 25, 2004 | 03:09 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
I will have to check that out. They used one on the CHP buoldup of a work truck. They were skeptical as well but I geuss they say a few ponies. You are right though and they would never critisize a mag sponsers product. HA! They need to hire one of us
Old May 26, 2004 | 03:28 AM
90RS305's Avatar
...HA! They need to hire one of us ...
LOL, I wonder what those interviews would look like?
Bruce (90RS305)
Old May 26, 2004 | 06:10 PM
irocbirdbuilder's Avatar
Car: 91 Camaro RS
Engine: TBI
I was jsut gonna post asking about this. I saw it in the new car craft and it supposebly did 8 horses, But it does look lik eit would raise the air filter up higher so i think when i get my cowl hood i may give it a shot. Seems liek it could help more than the spacer would.
"We instantly dubbed it the " soup bowl" and laughed that this could acctually accomplish a power gain. Our laughter turned to amazement when the soup bowl pumped the power up across the entire power band, adding 8 lb ft of torque at the peak and 8 hp! The key to this little piece is that throttle body injectors dotn breathe from the top becasue the injectors are in the way. Instead they breathe from the sides. The soup bowl merely creates a gentler radius that enhances lateral air flow, thus making more power." righ tform the cc article
It sounds to me like it gives it a some what swirling affect going into the bores. It also says in here that headers without additional fuel will actually loose power so now i'm super confused
Old May 26, 2004 | 08:54 PM
Car: 91 RS
Engine: 350 TBI
Why so confused? That's a known fact. If my memory serves me correctly, when they installed the headers w/o any other changes, they lost 1 HP and gained like 15 lb/ft or something like that. But when they added the Hypercrap chip they jumped up 20 HP and 40 lb/ft or something crazy like that, due to the changes in timing and the fuel curve. They also mentioned that if they had driven around much longer at those lean conditions that they would have scorched the piston rings or something to that effect.
I had the same effect when I first put on my headers as well. Although I noticed a slight improvement, I was at first highly disappointed until I put on the VAFPR and pumped it up. I then promptly failed my first emissions test, but I was happy none the less. I detuned it some in order to pass, and now I'm in the middle of an engine swap, so we'll see what happens when that's done.
Old May 27, 2004 | 08:09 PM
357mag's Avatar
Car: 94 C1500
Transmission: NV-4500
Axle/Gears: 3:42 10 bolt 8.5"
Gunny,
Mebbe ya need to re-read the article. The lean conditions existed before the Hypertech chip install. That's when they mentioned the WOT and mebbe melting a piston. As far as being a shill for the advertisers, I don't think they would use a dyno and mention the dyno shop's name if they were lying about the results. Has anyone thought that maybe the products actually do work? I'm not trying to flame anyone here, but I'd like to give a little credit where it's due. Dyno numbers don't lie.
My two cent rant...
Cheers,
Tim sends
Old May 28, 2004 | 05:12 PM
Car: 91 Camaro RS
Engine: TBI
i gotta agree with 357. I figure when i get my cowl hood here shortly and get it painted i might just have to order one. Worth a shot.
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
toronto formula
Sep 10, 2015 07:31 AM
scotrans am
Sep 5, 2015 04:26 AM
