WinALDL data analysis...
Old Mar 9, 2004 | 08:19 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
someone give me a 2nd opinion on this please..
this is my knock table:
http://josh.swoca.net/board/mrdude/t...4407_KNOCK.txt
notice around the 2000/60 range where i have all thoes knock counts? well look at my O2:
http://josh.swoca.net/board/mrdude/t..._194400_O2.txt
see the voltage in the same area? seems kinda lean huh?
heres my BLMs
http://josh.swoca.net/board/mrdude/t...194418_BLM.txt
INTs
http://josh.swoca.net/board/mrdude/t...194413_INT.txt
and last but not least, the log:
http://josh.swoca.net/board/mrdude/t...194806_LOG.txt
the car is a stock L03 with headers, single plane intake, and a open element
so do you think its lean there, and that makes it easier to knock, or what?
Old Mar 9, 2004 | 08:29 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
fueling seems ok, and where you are getting the knock at, is under part throttle, so your engien should be correcting. i would suspect timing, can you post your timing tables, and what is your base timing set at?
Old Mar 9, 2004 | 08:31 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
base timing is advanced 3*
timing tables is whatever is stock for the ANTT chip.
Old Mar 9, 2004 | 08:41 AM
Dewey316's Avatar
Car: 1990 Camaro RS
you might try backing it of to 0* and see if it still knocks. since that is an easy enough change.
Old Mar 9, 2004 | 08:46 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
i dont want to mess with that until i get some chips burnt..
after 2 weekends at the strip last summer, i determined that 3* is the ideal place for the motor.. or atleast for the best times..
im just wondering if its that far off.... doesnt seem right. like theres a lean hole there or somthing.
Old Mar 9, 2004 | 08:48 AM
Dewey316's Avatar
Car: 1990 Camaro RS
you can try giving it more fuel via the chip, the o2 can lie to you, but with the stock cam/heads and only a signle plane and headers, i don't imagine that being a lean issue.
Old Mar 9, 2004 | 08:51 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
what do you think about how far the BLMs are spread then?
Old Mar 9, 2004 | 09:15 AM
Dewey316's Avatar
Car: 1990 Camaro RS
well, there is the 1 cell that is 137, in your wide table, all the narrow readings are 122-130 with the expetion of the 135. but remeber those lean BLMs SHOULD be correcting. you really need a little more data, from some higher RPMs. it might be needing some more fuel, but not alot, i have ran my car wiht blms in the 140 range, with conservative timing, and it doesn't knock at all.
Old Mar 9, 2004 | 05:55 PM
Brent's Avatar
Where the O2 is .044-.077, INT = 128 and BLM = 137?
This is probably Lean Cruise mode. The BLM Enable column also shows the BLMs being disabled during lean cruise.
Old Mar 10, 2004 | 08:39 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
ahhhhhhhhhhhhhhhhhhhh.. i had a feeling i was missing somthing...
that hwy driving put it in lean cruise mode... good to know that i have lean cruise for gas miliage
thanks....
Old Mar 10, 2004 | 11:31 AM
Ronny's Avatar
when the KC happened to me at 2400-2800 and 30-40 map i pulled out 2 deg in those cells and went away. now i am going to add 2 deg adv in all cells and give that a go. my spark is very conservative stock(?) table.
Old Mar 10, 2004 | 11:26 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Yep, HW mode was probably in effect. Off the top of my head i think theres a coolant constant tucked away somewhere in the prom that you can set to zero (inv a/d counts) that will disable the HW mode completly so you dont have to worry about all your datalogs being skewed by low 02's and blms of 128 when you go above 50 mph or so.
Falcon50
Aug 22, 2020 03:26 PM
L98GTA87
Oct 19, 2015 10:43 PM
bjpotter
Oct 4, 2015 07:48 PM
MitcherNeaf
Sep 24, 2015 09:23 PM
BWilcox
Sep 20, 2015 12:19 PM
