It run's it's Alive and breathing fire...
Old Mar 10, 2004 | 01:38 PM
91 GTA Ramair2's Avatar
I got to hear my 406TBI rap on the Engine stand dyno gizmo.
542hp@6570rpm.
583Ftlb@5,150rpm.
it idles nice and choppy....
transmission is also about done.....
I can't wait to Drive this fine beast!!!!!
Old Mar 10, 2004 | 02:02 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: It run's it's Alive and breathing fire...
542hp@6570rpm.
583Ftlb@5,150rpm.
Wow great numbers. I take it you are using a 4BBl TBI set-up?
Old Mar 10, 2004 | 02:20 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
IIRC he is running a dual 4bbl
Old Apr 16, 2004 | 12:24 PM
Well guy's i was going to run the dual 4bbl holley comander 950 set up.
then i end up with a 1000cfm single 4bbl MPI with 8 injector's.
Old Apr 16, 2004 | 12:35 PM
Jegs parts numbers:
MPI system #510-534-183 .
Edle brock performer head's #60909.
Scoggin Dickey's parts numbers:
MSD ingnition #121-6420.
MSD Blaster coil kit #121-8203.
GM performance dist #1103952.
Super Street rotating assembly #SD616-2k.
TPIS parts numbers:
ZZ-X hyd. Roler cam #700-134.
Old Apr 16, 2004 | 12:45 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
So do you have any final dyno numbers other than the ones in your first post. That motor sounds really mean. Can't wait to see some times from that beast.
Old Apr 16, 2004 | 02:05 PM
i don't have any chassie dyno run's yet but it will all come in time .....I hope.
this Damn!! thing has been an on going project sence december 2002.
but i'm hopping to be completely done by summer 2005.
the $-) isn't flowing is fast as i'd like ...
Old Apr 16, 2004 | 11:49 PM
steve8586iroc's Avatar
I'm not trying to start anything here but your not running a tbi system as your first statement implies. You have a mpfi like you stated in your second post. The number of bores in your throttle body is not important when you are running an mpfi system, just the cfm it's capable of flowing.
Anyway, nice setup. Doesn't matter to me what you use for induction as long as the power is where you want it to be. I'm just a little envious :hail: .
Steve
Old Apr 18, 2004 | 10:01 AM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
uh yeah, thats not TBI but hey, congrats.
Old Apr 18, 2004 | 02:17 PM
YEAH GUY'S IT'S THE MPI SYSTEM i'M SPRRY i HAD THE dUAL tbi ON THE 350 DESIDED NOT TA RUN IT ON THE 406 YOU KNOW NEW ENGINE NEW SETUP..... MY BAD.
eightsixseven
Dec 16, 2024 01:50 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Fast355
Dec 2, 2016 06:33 PM
perZ
Aug 21, 2015 05:51 PM
ezobens
Aug 19, 2015 10:29 PM
