looking for BB injectors
Old Mar 10, 2004 | 07:25 PM
JokerRS's Avatar
Car: 92RS
Engine: 357
I posted an ad on the clasified board but am getting no responses yet. I tryed a part number for a injecter at GMpartsdirect.com and had no luck either. I would like to get a pair of 85# rochester injectors new or used. If any one can help hook me up it would be great.
Old Mar 10, 2004 | 08:11 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: looking for BB injectors
You're gonna have to look on ebay or in a junk yard.
Old Mar 10, 2004 | 08:14 PM
Brent's Avatar
The earlier 454 injectors are supposedly 85-90lbs/hr.
According to Mitchell and Alldata they are 17111784's and were used from 1987-1990.
Old Mar 10, 2004 | 08:54 PM
firedawg225's Avatar
Car: 1992 Camaro RS
Engine: 383 w/Holley Stealth Ram
Transmission: Pro-built 700R4
accually the earlier ones were the 80 lbs and the later model ones are 90
here are some numbers
80 1708430
90 5235231
Old Mar 10, 2004 | 09:21 PM
JokerRS's Avatar
Car: 92RS
Engine: 357
firedawg225, I tried those PN's at gmpartsdirect.com and came up empty. Brent, I tried 17111784 and came up with a price but they had no information as to application or flow rate. We could assume they were 85-90 lbs/hr but it would be nice to know for sure. Ive seen different charts and dont know which are correct.
Old Mar 10, 2004 | 09:55 PM
Brent's Avatar
If you want application try:
http://198.208.187.182/internet/Vehi...sReference.jsp
Old Mar 10, 2004 | 10:39 PM
Car: 1992 Camaro RS
I bought mine from Orellys and adavnce auto. those numbers work for cross references. or you can do a search on the boards there are alot of threads with injector numbers. there are so many to name it's easier if you do some searching.
I bought both 65 and 90lb injectors. and used the numbers on my web page which is what i gave you.
Old Mar 10, 2004 | 11:03 PM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
Try 17112560 for the 80's. I took that from z28boy.cz28.com , there's a lot of good pn's there. He doesnt have the 90's though.
Old Mar 11, 2004 | 09:58 AM
Ronny's Avatar
i have 90 lbs in my car gmparts direct. if you dont have a part # or year make model they are not of much help. if you like i can give you part#. email me. i will look up this evening. i am guessing 1990 chev truck 454. for some reason they upped size from 80-90. maybe 454 SS not sure. thay info on crossfire forum with search.
Old Mar 11, 2004 | 09:23 PM
JokerRS's Avatar
Car: 92RS
Engine: 357
I bid on a pair of 75 PPH injectors in a pod on ebay but some one wanted them more then I did. I think I'll hold out for some 85 or 90 PPH ones. Finally found some at gmpartsdirect but they are kida pricy. Still looking arround for some used ones for sale. I posted another add on our classified board but so far no luck.
Old Mar 11, 2004 | 10:01 PM
Lance Donlon's Avatar
Car: 91 1500 ex-cab pickup
Engine: 350 vortec
Transmission: 5-speed
How much is pricey
Old Mar 11, 2004 | 10:03 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Originally posted by Lance Donlon
How much is pricey
You are lookin at 50 to 70 bucks a pop for new GM ones.
Old Mar 12, 2004 | 09:28 AM
Ronny's Avatar
i think a lot more than that from gmdirect shifty. i have 2 new ones out of 454 TB that i will sell. TB is 1995 454. that is the issue. no one knows the #'s! the part# on it cannot be cross referenced. the FP is 26-28 per manual so that tells be 68 lbs BUT a 454 application. my 90 lbs are 12 lbs. so it would appear 68 lbs at 26 lbs is equivalent. the part # was posted several times. no one knows. i contacted a rebuilder and they have no GM#. brand new. anyone interested? i also have used 90,000 miles 65 lbs out of my vette,
Old Mar 12, 2004 | 05:48 PM
JokerRS's Avatar
Car: 92RS
Engine: 357
$99.00 a piece at gmpartsdirect.
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
thejimsterz28
Sep 15, 2015 04:37 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
