you guys think its a good deal?
Car: 89 camaro w/t-tops
Engine: lo3
TBICHIPS is doing engines now.http://www.tbichips.com/TBIMODS.htm
I was thinking of getting one since my 198,xxx lo3 is on its last legs.
I E-mailed him and had a response in my box when I checked it THREE HOURS LATER!(thats awesome response time!!!Mad props!:hail: ) anyway:
I may be interested in your potential Vortec 350 deal.How much for
a non-emissions engine ready to run?
thanks,
Rob
the response:
With throttle body, intake and chip will cost $2300+ shipping. Smog legal
would add about $300 to that cost and no throttle body would deduct about
$300. Standard long block crate motor would be $1800.
Brian
So, what do ya'll think?
thanks,
Rob
the response:
Brian
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
It depends what comes with his final package. See when you get into any engine swap or heads and cam stuff on your 305 you need the following stuff.
Chip burning
Fuel pump
Larger TBI unit with injectors
intake manifold
As you can see the long block is the last thing to go. You are going to nee these anyways with any serious power gains with your 305. So if you are going to need these anyways you might as well wait and just go with a LO5, L98 or 330HO crate.
Chip burning
Fuel pump
intake manifold
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
will he promise i pass emmisions
a hopped up cam in a 305, and i can't get past the sniffer test in OR.
a hopped up cam in a 305, and i can't get past the sniffer test in OR. Thread Starter
Engine: lo3
Shifty. re-read my first post.
Everythings included.Even a chip burned for the engine Its ready to run! So is a "drop-n-go" 300+ hp vortec 350 crate worth $2300?
Car: '90 RS
Engine: 377 LSX
Car: 1990 Formula
Engine: 305 TBI (LO3)
Transmission: 5 speed manual
Originally posted by ShiftyCapone
It is not a bad price I guess. You could get a LO5 shortblock, intake of your choice, and some worked L98 heads for just under that. However, this will be pretty much a true dialed in combo if he dyno tested it enough to get the chip right. It seems like you are going to need a larger TBI unit with injectors though and that can throw off the tune. I take it you already have upgraded yor exhaust and fuel pump. What intake does he supply with that?
Car: 91 RS
Engine: 350tpi comming soon!
Transmission: fixed the 700r4 again!
well i have an 87 L98 block with the heads that im goging to rebuild this summer , the nice thing it only has 95k on it so its in pretty good shape to start with but im goign toprob go with the holley 2 inch intake and 670 tbi with atleast #65 injectors and of couse some chip tunning.. this is what im thinking
block .030 over
forged psitions/rings 9.72 to 1
high flow oil pump
all new berings
new lifters, pushrods,and 1.42 ratio rocker arms
ported l98 heads with new seals and valve springs
cam i havnt figured out yet
( maybe lt1 or lt4 or sometrhing from comcams)
holley intake
either 670 tbi or 454 tbi unit
once this is odne and in with the mods i have in my signiture already and subframe conenctors im thinking i shold have problems hanging with lt1's and should be able to hit the 13's on a good day . I will prob go with tbichips.com atleast for the first few chips to get it running. i got one chip form his and i love it for my current combo.
block .030 over
high flow oil pump
all new berings
holley intake
hectre13
Dec 11, 2023 08:14 AM
86IROC112
Aug 17, 2015 02:00 PM
