305 heads
Old Mar 25, 2004 | 09:08 AM
rsarol's Avatar
305 heads
I have an 86 305, does anyone know what cc the heads are, or does anyone where to find information from the casting numbers?
Old Mar 25, 2004 | 10:05 AM
bbtaz97's Avatar
Car: 91 RS
Engine: 350tpi comming soon!
Transmission: fixed the 700r4 again!
there 58 cc's
Old Mar 25, 2004 | 10:30 AM
iroc22's Avatar
416 castings.
Old Mar 25, 2004 | 11:49 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Originally posted by bbtaz97
there 58 cc's
Correct
Originally posted by iroc22
416 castings
Correct
Old Mar 25, 2004 | 01:24 PM
steve8586iroc's Avatar
Are you converting to tbi?
Steve
Old Mar 25, 2004 | 02:01 PM
rsarol's Avatar
thanks for all the info, No i wasnt planning on converting to tbi, what i have is a 69 350 short block and I was considering putting the 305 heads on it, I know its not the greastest mod to do but since I am on a tight budget and trying to get this thing moving, I thought about givin it a try, I know it will increase my compression just not sure of how much, no even sure if it is do-able,
any thoughts about this would be appreciated
Old Mar 25, 2004 | 02:19 PM
What size cam are you going to run? As far as the heads go that shouldn't be a problem. Keep the octane up and the timming down unless your running a long duration cam witch will bleed off some compression in the lower rpm's.
Steve
Old Mar 26, 2004 | 10:22 AM
rsarol's Avatar
I have a comp coms 292h, but it has a pretty rough idle so i was thinkin about maybe goin with the 280h, could anyone possibly recommend a cam?
Jake_92RS
Jan 28, 2020 10:37 PM
gta90
Sep 15, 2015 04:00 PM
theurge
Aug 21, 2015 12:46 PM
