where is the TPS located?
Old Apr 2, 2004 | 09:55 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
dumb question but where is the TPS on my TBI? a picture would be wonderfuL! ty
Old Apr 2, 2004 | 09:58 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
if yuo look at the throttle shaft that goes thru the butterflys, you'll see a black box with a connector on it on the passenger side of the throttle body.
thats the TPS sensor.
Old Apr 2, 2004 | 09:59 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
i thought so, though , their is two plugs, one with 3 wires and the other looks like 4 wires
Old Apr 2, 2004 | 10:01 AM
Ronny's Avatar
IAC is 4 wire
Old Apr 2, 2004 | 10:03 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
excuse the huge pic, but its the blue, 3 wire connector at the bottom of this pic:
http://josh.swoca.net/board/mrdude/NewPics/IM000119.JPG
Old Apr 2, 2004 | 10:09 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
thanks! now one more question
which wire do i tap into for my nitrous kit that says hook up to my tps?
Old Apr 2, 2004 | 10:12 AM
vjo90RS8's Avatar
Car: 2002 Z28
one wire is a 5V source from the ECM, one varies voltage with throttle and the other is ground. My car has the newer style TPS with wire A is the 5V source, wire B is the varied voltage and wire C is ground. You can easily identify these with a multimeter, u can pick up cheap ones for about $5.
Old Apr 2, 2004 | 10:21 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
well i have an 89 camaro so im sure its the same.
so ineed to bridge my nitrous wire into the B line? cool!
sandman92084
Sep 12, 2015 10:27 PM
earlpote
Sep 12, 2015 11:55 AM
Jlanz55
Sep 6, 2015 02:35 PM
tonys91rs
Sep 2, 2015 07:07 PM
