need to run lean for emmissions test
Car: 86 Z28
Axle/Gears: TBD
car is stock with headers and afpr
i turn pressure all the way down it not low enought to remove hc
yes converrtor is new and all other equip is installed and functioning.
Car: '00 Chevrolet Corvette
Try going the other way with the fp. High combustion temps are the cause of HC (running lean raises the temp). That's why we've got EGR, to lower the temp.
Whoops. I was wrong about combustion temps and hydrocarbons. It's incomplete combustion that produces hydrocarbons. High combustion temperatures that produce NOx. Here's a link I found : http://www.autosite.com/garage/repairqa/ques078.asp
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
the computer WILL correct for you turning down the pressure.
take the computer out of closed loop. and then you can lean it down. not other way.
running hot and lean = high NOx and low HC's, until you get too lean, then high HC's and high NOx. just to clarify.
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
One warning about open loop, not all the emmisions equipment is fully functional untill the car is in closed loop. If you havnt already done so, roll back the fuel pressure to stock and check with winaldl that the blms are where their supposed to be. Also make sure you have a new A/C Delco O2, preferably heated for the headers. From what I hear, the O2 doesnt do much unless its up to around 600 deg F. After that, back the fuel pressure down a tad (if youll be doing open loop), throw some denat. alcohol in with the gas and see if it passes.
Car: 86 Z28
Axle/Gears: TBD
how do i get the car into open loop and
what are the blms supposed to be at and i can post my winaldl if anyone want to help.
as fars as a heateds o2 how do i install and where do i get it?
denature alcohol where acn it be purchased
Car: 86 Z28
Axle/Gears: TBD
i got passing co's and 2.00 on hc's but i need .80 or lower
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I would put the stock regularot back on and make sure your car is in a good state of tune. You should pass with ease with the mods you have.
Car: 91 RS
Engine: 350tpi comming soon!
Transmission: fixed the 700r4 again!
after i pout on my 3 inch convertor.. all i did is put basck on the stock chip and i passed with flying collors with whats in my sig
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
Got to walmart and get 5 bottles of heet brand gasline antifreeze and put them in the tank with some 93 octane. Retard your timing back to stock and make sure the car is over 200 degrees for the test. I just passed yesterday doing this.
Car: 88 Camaro SC
Engine: SFI'd 350
Car: 91RS_92Z28
Engine: 5.0_5.7
Transmission: WCT5_WCT5
Axle/Gears: 3.08_3.42
- Dimented24x7-
Why a Delco O2 Sensor?
Is Delco absolutly neccessary for our proper ECM readings?
I just picked up a Bosch Premium for roughly the same price as the Delco.
SHould I return it and why?
Any bad experiences before I throw the Bosch in and tear up my knuckles?
I too must pass IL epa before Friday or loose registration and license.
Car: '90 RS
Engine: 377 LSX
Originally posted by srdynamics1
- Dimented24x7-
- Dimented24x7-
Car: '90 RS
Engine: 377 LSX
what about the borgwarner variety
Car: 88 Camaro SC
Engine: SFI'd 350
eightsixseven
Dec 16, 2024 01:50 PM
92camaroJoe
Aug 13, 2015 06:07 AM
