Holley 670 Question
Old Apr 9, 2004 | 10:33 AM
White Thunder's Avatar
Car: 1991 Pontiac Formula Firebird
Engine: 350 TBI
Holley 670 Question
Those of you who have the Holley 670 TBI did you get a gold distribution ring? If so, did you use it? It seems that it would hinder airflow to me
Heck, there wasn't even anything in the instructions that came with the throttlebody that explained what to do with it. I only figured it out by reading about it in a magazine article.
Old Apr 9, 2004 | 10:41 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
You will only use that ring if you use a drop base open element. Youw ill get rid of the ring with a non drop base.
Old Apr 9, 2004 | 06:04 PM
Engine: 350 TBI
Excuse my ignorance but why is it necessary only with a drop base?
Old Apr 9, 2004 | 06:22 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
It is not essential but a non drop base clears the distributor with ease. I run a drop base but use the gold spacer and half inch spacer.
Old Apr 9, 2004 | 07:34 PM
Engine: 350 TBI
I was talking about the gold air distributon ring with the 2 tabs that Holley sent with the throttle body. I never new what it was nor where it belonged until just the other day when I was reading the "Performance Q & A" in the May issue of Chevy High Performance. Someone wrote in asking if the Holley throttle body solved the fuel distribution problems that the stock GM ones had. The responce was that Holley has a ring with 2 tabs that stick up into the airsteam in front of the pods to help pul the fuel to thefront of the intake manifold. Until I read this I had no idea what the ring was for and how it was suppose to be mounted . There was nothing in the instructions at all about. I figured it was some sort of adapterl
Old Apr 9, 2004 | 08:53 PM
va454ss's Avatar
Car: 90 454SS
Engine: 454 TBI
Transmission: TH400
Got any pictures of it?
Old Apr 9, 2004 | 08:59 PM
Engine: 350 TBI
I don't have any pictures right now, but I'll take some in the morning and post them.
Old Apr 9, 2004 | 09:01 PM
va454ss's Avatar
Car: 90 454SS
Engine: 454 TBI
Transmission: TH400
Thanks!
Does it have its own p/n?
Wonder if it will work on a GM TB.........
Old Apr 9, 2004 | 09:21 PM
Engine: 350 TBI
Yes, the article said the part number is 508-12. I'm not sure about wether or not it will fit a stock GM throttle body. I still have my original, I'll have to look at that as well in the morning.
Old Apr 9, 2004 | 09:31 PM
va454ss's Avatar
Car: 90 454SS
Engine: 454 TBI
Transmission: TH400
Checked that p/n at Summit. The descrip says its for 4bbl Projection.
Old Apr 9, 2004 | 09:42 PM
Engine: 350 TBI
Your right. I just went to Holley's web site and that is for the 4bbl. The 2bbl part number is 508-10.
http://www.holley.com/HiOctn/ProdLin...IA/508-10.html
Old Apr 9, 2004 | 09:44 PM
va454ss's Avatar
Car: 90 454SS
Engine: 454 TBI
Transmission: TH400
Thanks!
So, how is it oriented on the TB? I see a mounting tab, where does that connect?
Old Apr 9, 2004 | 09:58 PM
Engine: 350 TBI
You have to remove an injector pod mounting screw from the back right side of the throttle body and the screw goes back on through the hole in that tab. There's a notch in the inside of the ring that lines up with the raised part of the throttle body where the injector wires come through.
All in all I can understand the theory of how the tabs are supposed to help, I just have to wonder at whatcost to air flow restriction. I could call Holley and ask them but all I would get would be a pre-written, cue card type answer if any answer at all
Old Apr 9, 2004 | 10:04 PM
va454ss's Avatar
Car: 90 454SS
Engine: 454 TBI
Transmission: TH400
I may have to check that piece out.
Let me know if you can verify if it will fit a GM TB.
I remember reading an article on the 4bbl Projection, but don't remember the details about the ring.
It probably won't cause a restriction in my case; I have 2.2" bores
My application is a 454 and BBC's are known for running rich on the rear cylinders. This device, along with a TB adapter that mounts the TB forward on the intake may solve my problem.
Old Apr 9, 2004 | 10:09 PM
Engine: 350 TBI
I'll check it out in the morning and let ya know.
Old Apr 10, 2004 | 08:16 AM
Engine: 350 TBI
I haven't checked out if it will work on the stock Gm yet, but here are some pictures of it on the Holley
Old Apr 11, 2004 | 12:57 PM
va454ss's Avatar
Car: 90 454SS
Engine: 454 TBI
Transmission: TH400
Thanks for the pics and info.
I'll probably grab one of these and give it a try, even if I have to mod it a little bit. I'll "massage" it a little, like everything else I install
Frozer!!!
Jan 19, 2024 04:55 PM
MyRedCamaro
Dec 29, 2015 05:16 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
