02--- weird idle?
Car: GMC c1500 stepside 1989
Engine: 350TBI
02--- weird idle?
hi there,
i have a problem.
i have a new tbi engine that comes around 280hp
when i disconnect my o2-sensor it will run very good only at 4000rpm's it's over.(give a code)
my idle is perfect
when i connect my old or new o2-sensor the higher rpm's are perfect but my idle is very bad .(no error's in the computer)
it's going up and down and often the engine quits.
where must i look at?
also have 65 injectors/tbichips-chip/headers/open-airintake.
i have a problem.
my idle is perfect
Hey Shifty, I think you need to see your eye doctor and get some of those new computor glasses.
Both questions you asked were answered in his post. 350? Right under his name. Stock chip? In his signature.
Steve
Steve
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Steve
Steve
Well I sould have at least suggested the Tom do some data logging, then we can see whats really going on and maybe give him a better answer. I just sounds like it needs more prom tuning but a little more info would help.
Steve
Steve
Engine: 350TBI
Steve,
i, live in Holland(Europe) and data-logging over here is very expensive and very difficult.
i sent the specs of my new engine to TBICHIPS.com and they sent me a chip for this engine overhere.
i think my injectors for my idle are to big but for the rest of hte rpm.s i need them.
maybe another chip'??
i set the timing with the wire off on 0 degrees
the prom set the timing good isn't it?
thanks Tom
thanks Tom
Tom, if you have a laptop pc or can borrow one then you can get a data logging program called WinALDL for free and make a cable to hook up to your car for cheep. Just click on this web address and you will find everything you need.
www.winaldl.webhop.net
Steve
Steve
Engine: 350TBI
Steve,
thanks for the link
i just bid on ebay on a diagnostic cable and hope they sent me quick the cable.
i can borrow a laptop from a friend so..
i hope i can fix the problem.
i do the data logging and hope they can make a chip for me.
i'll post the data overhere and see.
i think within 2 weeks i have the cable so..
Tom
thanks for the link
Tom
