119 Mph And It Blew
Old May 22, 2004 | 12:45 AM
2kickassbirds's Avatar
Car: 1991 firebird formula
Engine: 5.8
119 Mph And It Blew
Ok so i going home and was wondering how fast i could go i hit 119 and this happened.
Old May 22, 2004 | 12:49 AM
Engine: 5.8
so what do you think happened?
Old May 22, 2004 | 01:06 AM
TiMMaH668's Avatar
Car: 92 Camaro rs
Engine: 305 tbi
Transmission: t-5
look like the dipstick popped out spraying oil all over the place.
how many miles are on your engine? looks like it might be in need of a rebuild
Old May 22, 2004 | 04:04 AM
90RS305's Avatar
Car: 96 Silverado/99 Suburban
Engine: 700 cubic inches of 'Muican Awesome
Transmission: 4L80/4L60
Axle/Gears: Chunky/Clunky
I can't even tell what we are looking at
Old May 22, 2004 | 10:24 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Agreed. Do you have a better pic.
Old May 22, 2004 | 01:15 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
from the picture it is very easy to see that...
...we cant tell what happened...
Old May 22, 2004 | 05:58 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Yeah that could be anything. Something leaking, excessive blowby causing oil spray.
Old May 22, 2004 | 06:15 PM
JokerRS's Avatar
Car: 92RS
Engine: 357
Were there any noises or other effects? Does it run ?
Old May 22, 2004 | 06:42 PM
ThraxXx's Avatar
Car: 1988 Pontiac Trans Am
Engine: 5.0L Fuel Injection
Transmission: Automatic 4speed /w OVerdrive
Your spark plug wires turned yellow from fear?
I have no clue what I am seeing either. All I see are rusty headers and an oil dipstick and what seems to be a chrome valve cover and some yellow accel wires. Explain what blew up.
Old May 22, 2004 | 08:01 PM
Engine: 5.8
you are looking at the passenger side header with oil burnt on it, no rust, it has 93,000 miles on it. just did the heads on it and i cant tell if it is the dip stick or what but something whent out on it. sorry thats as good as it gets as far as the pics go, yes it does run and runs pretty dan good except for the oil on everything
Old May 23, 2004 | 12:09 AM
Car: 88 Camaro SC
Engine: SFI'd 350
Oh, it jsut occured to me that the drainback ports in the head could be plugged up, preventing the oil from draining back down into the crankcase. Could also be a leaky valve cover gasket but it would have to be really bad to spew that much oil.
Old May 23, 2004 | 01:05 PM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
just for clarification......when somthing blows it usually involves chunks of metal seperating from the engine. You just blew a gasket or somthing. check and make sure your pcv valve and breather aren't clogged
Old May 23, 2004 | 01:34 PM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
Uh... a hole in the piston will cause the dipstick to pop out and spray oil every where. Broken ring lands from detionation will do it to. I`m thinking 383 will fix it
Old May 24, 2004 | 12:59 AM
jconrad's Avatar
Car: 89 Firebird
Engine: L05 350 TBI
Transmission: 700r4-slippin' on it's last leg
So it runs good without alot of excessive smoke from the tail pipes, no knocking or ticking noises? Just that oil on the header? What did you bolt the tang on the dip stick to, to hold it down? It is bolted down, right?
Ed1LE
Sep 30, 2018 09:14 AM
FormulasOnly
Jul 23, 2018 08:47 AM
darwinprice
17
Oct 11, 2015 11:51 PM
ZekeThorpe
Theoretical and Street Racing
35
Oct 7, 2015 07:30 PM
Gordonr1973
Sep 29, 2015 11:59 AM
