Testing FPR
Old Jun 9, 2004 | 04:15 PM
jeepguy553's Avatar
Car: 1980 Jeep CJ7
Engine: AMC 360 with GM TBI
Transmission: TF727 set for kill...let's get it on!!!
Testing FPR
Anybody got a good way to test a fuel pressure regulator? Mine seems to have bitten the dust, but WinALDL doesn't show a MALF code.
Help!!!
Thanks.
Old Jun 9, 2004 | 04:57 PM
Ronny's Avatar
bit the dust? i think only part is diaphragm and if it goes you would know it.
Old Jun 9, 2004 | 06:22 PM
BronYrAur's Avatar
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
Yeah FPR's don't really die its just a spring that limits the amount of fuel. Check your return line and feed line and make sure they're clear and ok. What makes you think its bad?
Old Jun 9, 2004 | 06:51 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
A bad regulator won't throw a code either. You could have a damaged or worn out diaphram but that is about it really. What symptoms are you getting that make you think it is a regulator problem.
Old Jun 9, 2004 | 07:02 PM
jeepguy553's Avatar
Car: 1980 Jeep CJ7
Oops...my bad. I meant RELAY.
I am a moron.
Old Jun 10, 2004 | 01:49 PM
Ronny's Avatar
check the defribulator on the relay. it could have a low elasticity coeficient.
Old Jun 10, 2004 | 01:51 PM
jeepguy553's Avatar
Car: 1980 Jeep CJ7
Is there a :flipoff: smiley here somewhere?
Old Jun 10, 2004 | 01:52 PM
Ronny's Avatar
Linson
Oct 24, 2025 02:00 PM
RedLeader289
May 28, 2019 01:47 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
Lmancha96
Sep 25, 2015 08:11 PM
