Valve Spring Advice
Old Jun 23, 2004 | 03:03 AM
iggy1991's Avatar
Car: Red 91 RS Camaro
Engine: LO3 with Comp Cam
Axle/Gears: 4th gen rear
Valve Spring Advice
I'm thinking about swaping in new valve springs since I couldn't afford to do it when I rebuilt the motor. I'm wondering about the stock valve springs specs like diameter and the degree of the valve locks and info on the retainers. I bought the cam from summit and they recommend these springs CCA-981-16 also from summit.
http://store.summitracing.com/partde...CCA%2D981%2D16
Will they install without any machining. Will I be able to use the same retainers and valve locks?
Old Jun 23, 2004 | 03:08 AM
CanCritterRW's Avatar
Car: 91 gmc 4x4 tbi :O)
whats a corvette servo and its purpose?
Old Jun 23, 2004 | 10:25 AM
iggy1991's Avatar
Its in the tranny...it helps it flow more fluid, I think, to help it shift better.
Old Jun 23, 2004 | 10:28 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Those springs should work fine. You could go a bit cheaper if you went with Z28 springs or K-motions. However, there are serious qualtiy and durability issues with those. I would stick with what you have picked out.
deracer
Apr 11, 2016 12:04 AM
Cameeeero
Sep 18, 2015 04:00 PM
gta90
Sep 15, 2015 04:00 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
