TBI not spray when crank !!
Old Jun 26, 2004 | 09:26 PM
halfline's Avatar
Engine: 305 TBI
Hello,
I'm new and hope you all don't mind.
I recently swap a 305 TBI from a 91 Camaro into my Jeep Wrangler. The whole project went fine but I don't get any fuel spray when crank the engine. I can start it by spray in some carb cleaner once the engine run....I got fuel spray out real nice and steady on both injectors as of no problem ever happened. My buddies told me that it needs more ground, but that didn't solve the problem. Could you Chevy folks give me some hints to look for? or what is wrong there?
I'm very glad to discover this board. Thanks all
Old Jun 26, 2004 | 10:49 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
I think there is a wire off of the GM ignition module that tells the ecm that the engine is cranking. Dont remember what color it was in the harness. Maybe purple/white? Its been discussed here before so a search may bring up some answers.
Old Jun 26, 2004 | 10:56 PM
Car: 88 Camaro SC
Engine: SFI'd 350
Checked the pin-outs on the 8746/7747, its pin C9 on the ECM, which will be purple/white in the harness. Dont know exacly what the signal is that the module sends. +5 volts, maybe? Anyway, needs to be hooked up for the injectors to work.
Old Jun 27, 2004 | 01:13 AM
halfline's Avatar
Engine: 305 TBI
thanks for the promt response, I will try that tomorrow but I can recall that I did purposely leave this crank signal wire out because I couldn't find out where to connect it. Could you tell me where this wire should be connected? You had mentioned that it should be connected to the injectors but at what point ?
So that's it ....I have not try it but I have a very strong feeling that this gonna solve my problem... just the one that I leave out came around and giving me trouble. Will let you know how it goes once I get the result.
Thanks again
Old Jun 27, 2004 | 08:10 AM
JokerRS's Avatar
Car: 92RS
Engine: 357
I think he's saying that it goes from the ignition module to the ecm. Good luck
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
MM2Robinson
Oct 1, 2017 09:16 AM
383cam
Sep 9, 2015 06:01 AM
Wylecoyote08
Sep 8, 2015 08:26 AM
