Adjusted timing myself this time...does this sound right?
Car: 1992 Camaro RS
Engine: 305 L03
Transmission: Borg-Warner WC T-5
I finally bought a timing light and adjusted the timing on my RS. It was showing it was about 2* or so advanced and I got it back to exactly 0*. I rechecked it after I tighted down the distributor and it was still perfect at 0*. So, just for the hell of it, when I hooked the ESC and battery back up I checked the timing at idle with the ECM involved and it showed it was holding steady at about the 3rd "V". Does this sound normal??? I might replace the knock sensor anyway, but just wanted to ask.
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
After you shut down and restart it should have quite a bit of timing added in from the ecm on top of the base time.
If you set it to 0 with the advance disconnected, when you reconnect the wire it should show far left of the "v's." If I had to guess I'de say around 20 degrees advanced, but you won't be able to measure it on the "v's" as it will be a few inches too far to the left. I hope that helps.
Car: 1992 Camaro RS
Engine: 305 L03
OK, thanks, I guess something is wrong then, because when I used the light after all was connected the mark was almost at the last "V"....
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Make sure you unplug the EST and not the ESC. I would go with a few degrees over zero for your base. A few degrees can make a nice difference in throttle responce, and fuel economy.
Car: '90 RS
Engine: 377 LSX
Originally posted by Dewey316
did you stand in the engine bay to take that pic ??
Car: '90 RS
Engine: 377 LSX
Originally posted by v8nate92RS
I bought my timing light at Sears for $45 and its a good one. Search for timing and you'll find instructions.
