torkerII with LT1 cam?
Car: 92 firebird and 95 trans am
Engine: LO3 and LT1
Transmission: 700R4-4l60E
i have an LT1 cam and i have a chance to get ahold of an edelbrock torker II intake manifold really cheap. i can also get ahold f an edelbrock torker1 pretty cheap is this a good combination to use or is the cam big enough to match the intake manifold
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Normally I would say no since single plain Torker intakes are best suited for high RPM applications. However, Dewey has been having great luck with his single plane and cam choice. He also is running the stock heads which really leaves out some HP in his high RPM parts selection. He will fill you in.
Engine: LO3 and LT1
i was planning on getting heads off of a rear end smashed 85 TPI trans am at a local scrap yard. they look good so far and i have some tools to do valve jobs and stuff. a guy i know will level and make sure they are true for like 60 dollars and mill them down for about 100 dollars. i would have to talk to him about clearancing the guides for a big cam. i got the lt1 cam free if that will not work with the intake i will just have to buy another cam that will work better with the intake.
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
I would highly suggest matching the intake to the cam, not the other way around. The intake isn't what determines engine vacuum, idle quality, etc. Why sacrifice a cam so you can use an older technology intake.
Car: 89 Camaro RS
Engine: 5.0 tbi
Transmission: street-strip 700R4
hey i just rebuilt my 89 5.0 tbi engine. i also put the lt1 cam on it but i have a edelbrock carb performer with a holley tbi adapter will that work fine?or maybe that the reason my car misses and is lil gay getting rpm and at idle i get code 42 i usaully change the module and the code will go but i put a new one 5 days i did my intake mani gaskets today because i had a leak but now i have the code back wat can it be?
Car: '90 RS
Engine: 377 LSX
New2Chevy
Sep 28, 2015 12:35 AM
