have a bunch of parts, have (the wrong) cam and need opinions
Car: '87 Camaro Z28
Engine: fully loaded 350
Transmission: T5-World Class
ok, these are the parts that will be installed in a few months (most of them are laying at my aunts house and I first need to get them shipped to germany)
list:
Hooker Headers
Carsound High Flow Cat
Air Dam
Lifters
Z28 Valve Springs
Timing Chain
Weiand Team G Intake Manifold
already here:
Thermostat 180*
Oil Temp Gauge
Air/Fuel Gauge
Oil Cooler
Complete Engine Gasket Kit
ARP Header Bolts
Radiator
Hooker Muffler
ok, now it seems, that I have a lousy cam (15 bucks from ebay...no problem
it's a lt1 cam out of a 95 caprice. that's what the seller says...so is there a huge difference between that and a f-car cam?
I know it's not THE way to go, but for the beginning I will have a custom made chip, but I will hang on the self prgramming...
so what kind of cam would you recommend besides a lt1 cam. could I get more gains with another cam or would it be too complicated to get it running/wouldn't be worth the effort?
or should I just get a "real" lt1 cam?
what do you think will be the result in the 1/4 or at the wheels with all the stuff?
greetings
S!MON
list:
Hooker Headers
Air Dam
Lifters
Z28 Valve Springs
Timing Chain
already here:
Thermostat 180*
Oil Temp Gauge
Air/Fuel Gauge
Oil Cooler
ARP Header Bolts
Radiator
Hooker Muffler
greetings
S!MON
Car: An Ol Buick
Engine: Vsick
Re: have a bunch of parts, have (the wrong) cam and need opinions
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Don't forget to add gaskets to your list. You will need a bunch of them
Intake (should include distributor and thermostat)
Timing cover (should include water pump)
Quality hedder gaskets
New TBI gasket
EDIT: About the cam. Any of the LT1 cams will suffice. Althought some were l;arger than others between the years and between the f and b body versions, they are all close enough. They are a good cam because they fit the TBI system well with tuning. They also are small enough where machine work to the heads is not necessary. I think there were 3 engine options for the 95 carpice.
LO5 (350 TBI)
4.8 LT1 (baby LT1)
5.7 LT1 (cop car only I think)
New TBI gasket
LO5 (350 TBI)
4.8 LT1 (baby LT1)
Car: '87 Camaro Z28
I've got an complete fel-pro kit for the whole engine
ok, then maybe I will give it a try!
maybe I will be able to contact the seller of the cam to get some more information.
any ideas on the output thing. I think that's a common tbi combo.
are 200hp at the wheels realistic?
greetings
S!MON
greetings
S!MON
Car: '90 RS
Engine: 377 LSX
Car: '87 Camaro Z28
back to life
have to bring that thread back, cause know I know that my cam is out of a 350 lt1 (95 caprice), buuuut:
in the table above the 265 and 350 b-bodies have the same cam specs except the rocker ratio, so what's the deal, cause people wrote that I should stay away from the baby-lt1. so there must be a difference, or am I wrong?
if it is so, what are the correct specs?
I get som 350' heads out of a 92TA. they will be ported etc. but the question is, will the lt1 cam reach the heads limits with 1.6 rockers.
some threds say yes, but if my lt1 cam is not that "radical" it could work....
questions over questions again, but I will do it once, and I will do it right
greetings
S!MON
greetings
S!MON
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
Typicaly stock heads can take between .470" - .480" lift without modification. If the total lift is not .470" you should have nothing to worry about. Other than pulling studs.
Car: '87 Camaro Z28
hmm, is this table I've made right?
1.5 rockers, left 1.6 rockers, right
lt1 caprice
int exh int exh
418 430 446 459
lt1 fbody
int exh int exh
447 459 477 490
tbi
int exh int exh
350 380 373 405
so:
caprice with 1.6 = ok (if these numbers are correct)
f-body with 1.6 = too much
tbi = :lala:
S!MON
lt1 caprice
int exh int exh
418 430 446 459
lt1 fbody
int exh int exh
447 459 477 490
tbi
int exh int exh
350 380 373 405
so:
tbi = :lala:
S!MON
