Motor gets slow at high RPM
Car: 91 Pontiac Firebird
Engine: 305 soon 350
When I hit the gas, it seems to go fast but as it gets around 3000 rpms it doesnt seem to go so fast and it makes a deep sound like its sucking for air, any body else have this problem?
Sorry, let me try to explain a little better.
When I'm in first I can hit the end preaty fast, but in 2nd, 3rd, 4th etc. when it gets past 2000 or 2500 rpm the car seems like it's almost not getting a good mixture, sometimes it will jump around like hesitating, sometimes it's worse than other times so I can't really figure out where to start looking. Hope this helps a little more.
Car: 91 Red Sled
Check your spark plug wires, sounds ignition related.
To do this just wait for no moon midnight, pop the hood and unhook the hood light, look closely for blue sparks, it's the best way.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Originally posted by danwaite
BTW What is the gap supposd to be on it?
I found an open vac line coming from the passenger side wiring harness that runs along the firewall, I took a screw and closed it off and now it seems to be much much quicker, I'll take a pic later cause I cannot find where this vac line goes.
Car: 1990 RS coupe
Engine: TBI 305.
Oh thats easy that engine has no top end I have the same one in my car it pulls respectably below 3k but anything above is nothing unless you have overdrive and well thats just a good way to empty your gas tank really fast I know from experience
do you have any experience with another 305 to compare it to or is this the only one youve driven?
My girlfriend used to have a 84 impala 305 carb, it was much faster than this. It's not only that it's slow it's just it shakes around and sound like it's hesitating the more you step on it.
Car: 91 Red Sled
I just changed plugs and wires. Any other ideas ?
It really still sounds SO much like a bad plug wire.
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
If you don't have an open element air cleaner yet (I'm assuming this is an L03?), do that and see if you like it better.. Putting a 14x3" (triangular edelbrock with K&N) air cleaner on my brothers L03 '91 bird drastically improved performance (pulls up high now)... Just a thought..
Car: 75 nova 11.15 @ 125, 92 1500 14.60 @97, 95 integra 15.80 @ 91
Engine: 377, 355, 1.8L
Transmission: t350, 700r4, m5
car
im having the same problem and know one can seem to give me an anwser. its kindof hard to explain what its doing isnt it?? mine pulls untill 3500 and falls on its face. it wont rpm above 3500 and wont even shift untill i let off the gas if im floored. if im just cruisin you wouldnt ever know it does this. mine in a 92 350 truck though with a brand new motor. never did this before. the only thing i can thing of is the timing chain is off a key or somethings clogged in my exaust. another thing i just found out about from several people (true or not) is the factory stainless exaust has to layers and the inner layer can somehow close up?? it gives somehow causing people to think they have a fuel problem. i dont have the extra money to take a chance at buying new exaust for a theary though
Problem Solved, It was just the stupid 4.99 fuel filter. Well it could of been worse, thanks for all the input.
Dan Waite
Dan Waite
the one you just put on now that fixed your problem ws an auto zone filter??? thats what ive been using and never had problems in the past. what brand FF??
eightsixseven
Dec 16, 2024 01:50 PM
