air pump delete..
Old Aug 15, 2004 | 07:43 PM
JeffC1500TBI's Avatar
air pump delete..
anyone know how to get rid of the air pump? my headers have the connection for it.. do I just plug that part and get rid of everything else? I tried unplugging the connector on the air vavle one time while the vehicle was running and it stalled.
I just got really anoyed taking my heads off and having all this air crap bolted to the rear of the heads.
Old Aug 15, 2004 | 07:48 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
The new to tbi sticky up top has links on how to do it. I used brass pipe caps to plug the AIR fittings on the headers.
Old Aug 15, 2004 | 08:01 PM
so basically I can get rid of it all. I just leave the connector unplugged and plug the vac line.. then put a cap on the connector on each header?
Old Aug 15, 2004 | 08:21 PM
BronYrAur's Avatar
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
Yep, that's what I did. I took off the whole pump and pulley too. You have to use a slightly different belt routing then and I think the belt size was 96.8"
Old Aug 15, 2004 | 08:33 PM
yeah the belt thing is not a problem for me. I can buy the shorter belt. the air pump stuff was on some trucks & not others so it had both options.. even the diagram for belt routing under the hood shows how to route with & without air.
I'm wondering since the headers are off right now if I should grind the nipples sticking in to the exhaust. I thought I read something a while back about grinding them so they are flush. the other thing I read before was the connector for the divert valve could be used to power a heated o2 sensor.
for some reason I remember a few years ago when the engine was running I unplugged the connector on the divert valve and the truck stalled. ecu does not monitor that in any way though?
Dialed_In
Aug 20, 2015 01:45 PM
actionj
Carburetors
Aug 16, 2015 09:51 AM
mcquigg
Aug 13, 2015 02:26 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
