codes 43 and 51
Old Aug 18, 2004 | 12:32 PM
rad8tion's Avatar
Car: 92 RS Convertable
Engine: RAMJET 350
Transmission: G-FORCE T-5
codes 43 and 51
ok been having a few problems with my car for a month or so. thought it bight be chip related so I just started burning chips. yesterday it ran just fine on my new chip (my first one)and today I got about 3 blocks and lost lots of power and got codes 43 and 51.
Anyone have any ideas?
any help would be much appreciated
thanks
Ryan
Old Aug 18, 2004 | 12:40 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Error 43 is ESC error. The knock sensor circuit has failed the forced knock test due to no knock being detected or runaway knock is present. Might be ignition timing is retarded (or advanced if there is runaway knock), the knock sensor and/or module is bad, or there is a wiring fault.
Error 51 is a prom error. If you get a flashing SES light ever that means that the prom is either not present, there is a bad contact or something, or the checksum of the prom is incorrect.
Old Aug 18, 2004 | 12:48 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Sometimes you will get a code 43 with any cam swap and a tune that is close to stock. The forced knock test won't work and you will get the code.
Old Aug 20, 2004 | 09:57 AM
rad8tion's Avatar
Engine: RAMJET 350
Hmmm.. I am starting to wonder if I blew a head gasket or something
thanks
ryan
Old Aug 20, 2004 | 09:59 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
thanks
ryan
I doubt that. A few data logs will tell you whats up.
Old Aug 20, 2004 | 10:23 AM
rad8tion's Avatar
Engine: RAMJET 350
car ran great for a year and a half (on a stock chip) and now runs like crap and I can't figure out why.
replaced all exhaust gaskets plugs wires cap and rotor injectors fuel pump. I'll try and get some data logs today. What should I look for?
thanks again
ryan
Old Aug 24, 2004 | 08:48 PM
rad8tion's Avatar
Engine: RAMJET 350
arg can't upload a data log to this post, and there for can't beg for help
Old Aug 24, 2004 | 08:55 PM
Gladstoneiroc's Avatar
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
Have you tired with the old chip again?
Old Aug 25, 2004 | 10:32 AM
rad8tion's Avatar
Engine: RAMJET 350
yep to no avail
Thanks for any help
Ryan
Old Aug 25, 2004 | 10:46 AM
rad8tion's Avatar
Engine: RAMJET 350
I think it has to be a sensor or something mechanical.
it runs great at part throttle but it has no power when I romp on it. Also the cat some how gutted it's self.
would any body be intrested in being kind enough to look at some data logs?
thanks again
ryan
Old Aug 25, 2004 | 01:09 PM
Car: 88 Camaro SC
Engine: SFI'd 350
If its throwing a code 43 then itll definatly run like crap. The ecm sets full retard when a code 43 is set. Ill take a look at the logs, my emial is in the new to tbi stickie at the top of the board.
Old Aug 25, 2004 | 03:42 PM
rad8tion's Avatar
Engine: RAMJET 350
Dimented you have mail
Thank You
ryan
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
