Code 53 where to look at solving
Old Sep 1, 2004 | 10:46 AM
thedogs's Avatar
Car: firebird '89
Engine: 305 tbi
Transmission: it works I'm happy
Hi
Yeah my car just passed inspection, NICE!! It drove there fine no problems or codes but on the way home I got a SES.
Code 23 and 53, I've already reconnected the MAT sensor. The mechanic had dropped it in the engine bay and just left it there ah well !!
I've also recently fitted a MSD coil and dropped a load of dry gas in the tank. I also caught the alternator wire whilst working and got a spark but after all these I had no codes.
Any suggestion as to what this might be, I don't understand what "system over voltage" means. The haynes manual sucks I know, and tells me the trouble code but nothing more. Any and all suggestions I'm gratefull for. Oh my drive belt is tight as well.
thanks in advance
Old Sep 1, 2004 | 10:52 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
The meaning of your code 53 would depend on what year your car is. If it is a 89 or later it would mean a problem with VATS.
Old Sep 1, 2004 | 01:26 PM
thedogs's Avatar
Car: firebird '89
Engine: 305 tbi
My car is a '89 tbi 305 firebird, auto ,engine code E.
Appreciate any help trickster, thank you.
Old Sep 1, 2004 | 01:30 PM
thedogs's Avatar
Car: firebird '89
Engine: 305 tbi
oh VATS?? . What is it where is it? isn't part of my emmissions?
That vapor fuel canister thing behind the drivers headlight anything to do with it?
Old Sep 1, 2004 | 02:01 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
No, it isn't a part of the emissions. It is that little pellet in the key and stands for Vehicle Anti-Theft System. Have you been having a problem starting the car at any time? Disconnect the battery for a couple of minutes to clear the trouble codes and then drive it to see if the codes come back. It could just be an intermittent fault.
Old Sep 1, 2004 | 04:23 PM
thedogs's Avatar
Car: firebird '89
Engine: 305 tbi
I don't have a problem starting the car but theres a loose wire in the key area because theres an intermittent buzz that stops if you wiggle the key a little.
I'm going to go and disconnect the battery right now and let it reset. I'll do a search first on changing the ignition/key turny bit/whatever it's called. Unless you know a good thread to look into changing it. Thanks for your help again trickster.
Old Sep 1, 2004 | 04:59 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
If you'll do a search you'll turn up a couple that I have posted with diagrams as well as the one that Vader has posted. If you can't find them let me know.
Old Sep 1, 2004 | 05:17 PM
Benm109's Avatar
Car: 1991 Chevy Camaro
Engine: 305 TBI
Are you talking about me, Trickster?
If you do a search you can find out how to change the ignition lock cylinder, if that's your problem. I did it not too long ago. I wouldn't say that it is hard to do, but you do need a couple of special tools and some patience.
Old Sep 1, 2004 | 05:50 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Nyah, I wouldn't do that Benm109. Besides, if he has to change his out he doesn't have to worry about the airbags like you did. BTW, how is your ride behaving these days?
Old Sep 1, 2004 | 09:47 PM
Benm109's Avatar
Engine: 305 TBI
My car's just fine (for now ). I'm currently waiting for my SFCs to arrive so I can install them! :lala:
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
Pac J
May 17, 2020 10:44 AM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
