Tbi Powerplate
Car: 1991 Camaro RS
Engine: Stock 305 TBI
Transmission: Stock
Tbi Powerplate
Anyone used one? They're claiming somehwere between 10-15 horsepower increase. The fact that its a money back garuntee is intriguing as well... Any ideas?
http://www.cfm-tech.com/TBIPOWERPLATEinfo.htm
I'm probably going to get one of their throttle bodies anyway.
Car: 1988 Pontiac Trans Am
Engine: 5.0L Fuel Injection
Transmission: Automatic 4speed /w OVerdrive
I read all the articles on that site and it seems that those guys really did some mad airflow research. I am real tempted to pick up one of those spacers however I am kinda erie on if it will fit under my hood. I do have a drop base aircleaner though so it might go in no problem.
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
From the CFM website:
CFM TECHNOLOGIES - See below statement - Check local emmission's laws for your application
All products in this website are not legal for sale or use on CA pollution controlled vehicles
Sheesh.
Sheesh.
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
I don't see how it would effect emmisions at all. and it is a 15min job to take back off for inspection
the spacers do seem to give you a little something. The added plenum volume from it is likely where the benifits come from. I had a cheapy spacer on my car when i had the stock intake on. I have no before/after numbers. but my car did go 15.1@92mph with a spacer, headers, 3.42's, and computer work, nothing else was done to it.
Car: 92 Camaro RS, 90 Camaro RS
Engine: 346 LS1, 305 TBI
Transmission: 4L60E, 700R-4
Axle/Gears: 10 bolt:3.42, 10 bolt:??
I would say its worth it...cant find the price on there but it cant be that pricey, not to mention money back garentee.
Dewey:15.1 aint bad with those little mods, Ive heard headers are the best bolt on when it comes to power gains for TBIs.
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
The spacer will probably have little effect other then raising the tbi, which can cause problems sometimes. I doubt it would add 15 HP but it does increase the plenum volume a bit and allow for some sharing of the bores.
Car: 96 Silverado/99 Suburban
Engine: 700 cubic inches of 'Muican Awesome
Transmission: 4L80/4L60
Axle/Gears: Chunky/Clunky
Actually now that I read into it a little bit it does make a lot of sense on how it would increase power... I would LOVE to see some dyno numbers on that thing... If anyone decideds to get this thing PLEASE let us know! If not, after I figure out whats wrong with my transmission, I just might...
Bruce (90RS305)
Bruce (90RS305)
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I can only see a spacer adding power when you have a nice cam and heads. Otherwise the stock cam is so lame the stock intake can feed it for the time being. A little more plenum volume may help but I doubt you will notice anything on the stock set-up. Although I have no before and after track times, the butt dyno felt nothing when I added a spacer over 4 years ago. I do one day hope to dispell this spacer myth. In the next year or so I should be getting another TBI car to play with from scratch and hope to put to rest many issues people have. I think it is possible for one to see some slight gains only after they have a heads and cammed set-up with the proper tuning.
Shifty... car all fixed up now? (or was that accident way long ago?)
~C
Car: '90 RS
Engine: 377 LSX
~C
~C
Car: 88 formula WS6
Engine: 305 Lo3
Transmission: 700-R4
Yeah, I said a little pricey but look at it this way, if it really would add at least 15 hp. to a 305 for about 90 bucks (incl. S&H ), would it be worth it? People pay more and do a lot more work installing headders for about the same power gains (15-20hp)
because they know it will improve power! Fact is, we don't have a positive testimonial on the intallation of the plate yet. If someone has installed one and said definate improvement, I'd have the money in the mail tomorrow!
Car: 88 Camaro SC
Engine: SFI'd 350
Id have to see independant dyno graphs with several runs back to back showing the 10-15 HP increase from using the spacer. With all those adds 20 hp garbage bolt-ons sitting around on autopart store counters I have a hard time believing any of that unless I see conclusive results. I imagine that it may help, but those are pretty large increases theyre claiming just from adding a little more plenum volume and allowing the bores to be shared a bit.
You know what they say. If it sounds too good to be true, it probably is.
Car: 88 Camaro SC
Engine: SFI'd 350
Looking at their catalog their prices are just astronomical. 300 dollars for a warmed over stock prom, 75 something for a regulator, YIKES!!!
rs_z28_vert
Sep 30, 2015 09:47 PM
