Next Mod?...
Old Oct 28, 2004 | 07:16 AM
JerseyMark's Avatar
Car: 1991 RS Convertible
Engine: 96 LT1
Axle/Gears: 3.45 9-Bolt
Next Mod?...
Hey guys,
I am itching to do another mod. What would be the best bang for the buck mod for me. I was thinking either some computer tuning or some 1.6 rockers. What do you think. Check my sig for my current mods.
Old Oct 28, 2004 | 07:30 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
headers and computer tuning.
Old Oct 28, 2004 | 08:29 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I think he has headers already based on his sig. I second chip tuning though. Headers really throw the tune off and if you plan on swaping cams nows the time to learn.
Old Oct 28, 2004 | 11:33 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
'Nother vote for chip tuning. Having that will be necessary to do future mods. Without it, the computer will fight you.
Old Oct 28, 2004 | 02:52 PM
cali92RS's Avatar
Car: White KSwisses
Engine: 5.3L Gen III
A different perspective:
STB, LCAs, PHB, torque arm, sway bars, Shocks/Struts, Springs
Old Oct 28, 2004 | 08:26 PM
Formula4Speed's Avatar
Car: 1990 Formula
Engine: 305 TBI (LO3)
Transmission: 5 speed manual
intake manifold...i started swapping mine and lost interest half way through which seems to have made my car not run...
Old Oct 28, 2004 | 10:24 PM
JPrevost's Avatar
Car: 91 Red Sled
My perspective;
Tuning, LCARB with SFC, LCA poly bushings, Bilstien struts, carb intake with adaptor plate and make stock FPR adjustable (fuel pressure bumped up), springs, sway bars, in that order.
Tuning first since you've got headers already and stock tuning is already weak (Gm didn't want TBI performing close to TPI ).
The LCARBs are highly recommended since you've got the gears and posi to induce teeth chattering wheel hop.
Old Oct 29, 2004 | 11:50 PM
25THRSS's Avatar
Do all of your engine mods first, then tune. That way you only have to tune for one optimal combo. Just my
Old Oct 30, 2004 | 12:12 AM
JPrevost's Avatar
Car: 91 Red Sled
I think it's best to start tuning with a stock motor to see what you can do/get away with and the results. Then doing another mod, tuning, results, "oh look, the engine needs more timing down low RPM with the larger cam." This way you've learned and everything goes smoothly. Trust me, I did my engine swap and was having a HARD time getting a good baseline tune. I dove in head first and know how hard it was so trust me, if you are looking for getting 100% out of the engine and awesome drivability, start tuning ASAP or you'll spend at least twice as long trying to tune a radically different setup.
Pac J
May 17, 2020 10:44 AM
Mark_ZZ3
May 24, 2018 01:02 PM
383backinblack
Oct 14, 2015 08:50 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
