Anyone ever had this problem?
Old Nov 6, 2004 | 10:14 AM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
So , ive had this problems for a while, but i just got my car up and going again after a tranny swap. after the car warms up every once in a while it will hesitate a little bit. Especially if you are coasting for a minute and then you hit the gas it will kinda bog down and they it will go. And sometimes like if im sitting at a red light for a second and the light turns green and i look in my mirror and when i start to go it will throw a bit of smoke out, and it smells real rich. Then sometimes it will even do it if i am just idleing, the RPMs will jump up and down. Yesterday i did the following: took the throttle body apart and cleanedthe whole thing out, change the fuel filter, air filter, set the timing back to zero and change the oil. It runs alot better now but the problem still exists.
Old Nov 6, 2004 | 11:00 AM
bulletboy29's Avatar
Car: '87 Camaro SC
Engine: 305 LG4
Black smoke?
Have you done the old tune-up routine? I would replace plugs, wires, cap, and rotor and see if the problem goes away.
Old Nov 6, 2004 | 11:04 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Its too much fuel in the tables and probably too much accel enrich. Or maybe jsut too much fuel and it bogs out when the accel enrich is added.
Old Nov 6, 2004 | 11:06 AM
Car: 88 Camaro SC
Engine: SFI'd 350
A tune up may also help if you havnt done it in a while but if it still persists more tehn likely its a problem with the 'stage 1 chip' that you have.
Old Nov 6, 2004 | 12:27 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Put the stock chip back in and bump your base timing up a degree or 4. I bet everything will be back to normal and your car will run 100% better. Off the shelf chips make your car run like poo.
Old Nov 6, 2004 | 10:03 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
Black smoke?
No, its more of a greyish color smoke, i think. And the plugs,wires,cap, and button have been changed just recently also.
As far as the chip goes, it came from tbichips.com. I have the stage one and 2. what the difference is, im not sure. Anyhow the problem with the stock chip is that i dont have one. a While back i was going to put it back in and one of the pins broke. Anyone know where i can get another? I am going to buy a cable to run Winaldl and ill post the data when i get it.
Old Nov 8, 2004 | 04:44 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
ok, i figured it out, i plugged up the EGR and it hasnt done it since. Howver i would like to fix the problem instead of just patch it, do i need a new egr vavle? what do i need to fix it?
Old Nov 8, 2004 | 05:02 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Maybe sure the diaphram moves freely. They can get gumed up and stick over time. I wouldn't be suprised if that chip dumped unneeded fuel into the motor. It may be time for a new valve though. Almost every GM vehicle will need a new EGR valve sooner or later.
Old Nov 8, 2004 | 06:11 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
Do i need to take the EGR vavle off to check it? Also, if it is gummed up, do i need to buy a new one or just take it apart and fix it? Also with the chip, i took the stage 2 out and put in the stage one, at first i wasnt impressed with the performance, then i bumped the timing up to 6 degrees, and man, she sure came to life after that.
Old Nov 8, 2004 | 07:15 PM
Car: '87 Camaro SC
Engine: 305 LG4
If it's like my carbed 305 you can just put your fingers under it and pull up on the diaphram without taking it off.
Old Nov 8, 2004 | 07:37 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Yup. You can get a finger or screw driver in there. Carbon chunks can get in there over time. They have vacuum testers to test their ability to open and close. Stage 1 and 2 chips add a bit of timing and fuel but are not necessarily introducing the two when they are needed. Hence, people usualy have idle and off throttle problems as well as audable pining.
Old Nov 8, 2004 | 08:48 PM
azvolfan's Avatar
Car: currently thirdgenless!!!
Del,
Check the junkyards in your area for a Camaro computer. If they have one you can use the chip from that. Supposing ofcourse that it has a stock chip in it. Should be pretty cheap.
Old Nov 8, 2004 | 09:02 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
i am going to look into that, so far, i emailed tbichips.com and he said he could get me one in a holder for 20 dollars. I dont think thats too bad of a deal. im gonna check the EGR vavle too. I would like to have it operated like is supposed to. Thanks for all the help!
Old Nov 8, 2004 | 11:02 PM
azvolfan's Avatar
That's pretty good. A computer from a junk yard would cost that much.
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
