Should I cut or leave alone?
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
Should I cut the adapter plate or leave it alone. I just received this from CFM.
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
You could notch it to match the intake, but youd have to be very careful that there is enough gasket surface remaining to seal off the bores and vacuum port passages under the tbi base.
Thanks for the reply, I will make sure to measure and re-measure to get the right cut. Will post pictures once the cut has been made.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Car: 88 Camaro SC
Engine: SFI'd 350
This should help. Everywhere in red must be in contact with the gasket on both surfaces and each must be free of nicks and gouges in that area.
Car: 88 Camaro SC
Engine: SFI'd 350
As for the gasket, take teh plate off when your done and mount the tbi to it. Then turn the plate/tbi over and trace and/or cut out the portion of the gasket that overhangs. I did this to make my gaket for my holley tbi when none of the ones for the larger tbis where available.
gta892000
Sep 16, 2015 12:37 AM
RyanJB
Sep 14, 2015 03:39 PM
