Stock intake manifold
Old Dec 14, 2004 | 06:31 PM
Breazlan's Avatar
Car: 88 Firebird
Engine: 302 SBC
Axle/Gears: 4.27 Dana 44
Is the stock intake manifold that much of a detriment to low end power (below 3500 rpm)? Thinking of using a stock intake man. for my truck.
Old Dec 14, 2004 | 06:55 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
The stock intake is enough for a stock motor but becomes a restriction when any type of performance mods are added. Basically, everything that bolts onto a TBI motor in stock form needs to go.
Old Dec 14, 2004 | 07:50 PM
Breazlan's Avatar
Car: 88 Firebird
Engine: 302 SBC
Also, are the 305 manifolds the same as 350 manifolds?
If it is, the 305 won't be as affected by the restriction on the low revs. What is the restriction in the manifold?
Old Dec 14, 2004 | 08:35 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
The intakes are the same but with different part numbers. The problems with the stock intake are its small plenum and runner size along with its entry angle into the ports. It all around is a straw. Dont worry about the low revs. When you need it, a properly matched intake with (insert combo here) will retain all of the low end as well as provide sufficient high end flow.
Old Dec 14, 2004 | 08:46 PM
Breazlan's Avatar
Car: 88 Firebird
Engine: 302 SBC
What intake is a high velocity intake to use? I currently am using a dual plane that could probably classified as a high rise. Response seems too squishy and am thinking it could be the intake plenum size.
Old Dec 15, 2004 | 07:08 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
There is a good write up on intakes in the TBI stickies above. Some cover parts and another by Dimented goes into intake selection with TBI. That should help you out.
Old Dec 15, 2004 | 07:57 PM
red90bird's Avatar
Car: 1990 Firebird
Engine: LS3
I don't mean to hijack your thread
I have sort of been wondering sort of the same thing but my question is: what is a good intake to use the with holley 670 tbi?
would a single plane intake with an adapter work better or a dual plane with some kind of adapter be better?
again I don't mean to hijack your thread but it seemed to be a good time to ask
Old Dec 15, 2004 | 08:55 PM
Reds ttype's Avatar
Car: Turbo Buick
Engine: whistling V6
Transmission: lots of broken ones
on a 305 the stock intake should be fine
the truck exhaust manifolds totally suck tho .. summit has headers that bolt in place of the manifolds for ~ $ 150 then like ` $180 for flowtec's I opted for stainless steel headers so I wont have to worry about then rotting out
I just bought then from this place on ebay
http://cgi.ebay.com/ws/eBayISAPI.dll...e=STRK:MEWN:IT
as for an intake for the holley t/b .. why not get the holley intake? thats what I used on my truck with a 454 t/b
Intake was ~ $175 from jegs or summit
Jake_92RS
Jan 28, 2020 10:37 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
86IROC112
Aug 17, 2015 02:00 PM
st.evel07
Aug 13, 2015 06:15 PM
Jake_92RS
Aug 11, 2015 10:39 AM
