I replced my LO3 ECM with one from a 4.3 sonoma
Old Dec 16, 2004 | 05:57 PM
The_Wraith's Avatar
Car: 1984 Trans Am 15th anniversary
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
Now that I have you attention my car died out of knowere and would not start.I noticed that when I turned the ign on the SES light did not come on.So I went home and grabbed the ECM out of my 91 4.3 sonoma,plugged it in reset the batt and she fired right up.It seems to run ok maybe a bit stubbly but that could be from not full tightening the batt cables down.Is it ok to use until I located a proper replacement?
Old Dec 16, 2004 | 06:43 PM
The_Wraith's Avatar
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
I did a search and s10 owners say the ecms are the same and that my car will run lean (which it is) and that I can switch the proms from my car to the 4.3 ecm.can anyone verify this?
Old Dec 16, 2004 | 06:50 PM
JPrevost's Avatar
Car: 91 Red Sled
They're wrong, lol. So wrong it isn't even funny, like ah... hmm... it's just easier if I call them stupid .
The chips don't interchange and your 91 4.3 doesn't use the same ecm as your camaro. If it did it would have the same number on the outside. Your ecm is a 8746, this means it's different, different as in the ROM code that's built in. Basically speaking if you put the a chip in from a different ecm number it won't run! Code is stored in the ecm (rom) and they look up different locations in the chip (eprom).
The ecm itself uses very similar inputs as your s10, this is why it runs. I think you had better get a replacement ecm before you blow up (apart) your engine. ECMs are a lot cheaper than the engines... at least where I'm from they are. Not to mention the time it takes to actually replace....
Old Dec 16, 2004 | 06:56 PM
JPrevost's Avatar
Car: 91 Red Sled
Could you send me the link that has an s10 owner telling you they are the same and that it will run lean.
Old Dec 16, 2004 | 08:18 PM
The_Wraith's Avatar
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
Post Per Day: 0.02
Trader Rating: (0)
User is: OffLine
Hi,Up to 1992 s10 4.3L V6s USE a 700r4 trany,If you use a 305 or a350 Chev. The ECMs are the same,but you will need a PROM chip from a 1/2 ton P-U the same year as your s10, with the same options.For 1993 to 1994 the 4.3L uses a 4L60E tranyThe 93 or 94 ECM#16196395 or 16197427 are the same for 305 or 350 chev but you will need a 1994 1/2 ton p-u PROM same options this makes everything work. (DTNLUB) TOM
http://www.s10forum.com/forum/showth...&highlight=ecm
My engine will blow up? can I used a ecm from a fullsize LO3 pickup?
Old Dec 16, 2004 | 08:29 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
To my understanding truck ECM's are also non compatable without a lot of work. Just get one out of an LO3 car in a junk yard. There are millions of them out there. By blow up he means irreversable damage due to improper fuel and spark management. Even a new ECM at autozone is like $70. Why risk it.
Old Dec 16, 2004 | 10:12 PM
JPrevost's Avatar
Car: 91 Red Sled
Post Per Day: 0.02
Trader Rating: (0)
User is: OffLine
That guy isn't talking about the 8746, he's talking about the 7747 which came in the trucks. A 7747 will plug right in, you'd still be shooting yourself in the foot.
Your engine won't blow up, but it could be damaged. Just get an 8746 from a full size b-body (caprice) or 89-92 TBI f-body. You could also get an ecm from an 88 but why bother with the vats issue, just get the right ecm.
Old Dec 16, 2004 | 10:48 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
The real issue with using a V6 ecm is that the ecm will register the rpms as higher then they actually are with a V8 since there will be 4 reference pulses rather then 3 per revolution. The fueling and spark will also be off but maybe not by too much.
Just get another 8746...
Old Dec 17, 2004 | 04:13 PM
The_Wraith's Avatar
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
Update I plugged in my old ECM and boom it now works.But before the SES light would not come nor would the car start.I drove it all day and it ran great.Maybe I should buy a backup?
Old Dec 18, 2004 | 03:43 PM
Car: 88 Camaro SC
Engine: SFI'd 350
I certainly would.
Old Dec 19, 2004 | 12:09 AM
studdmstr's Avatar
Car: 91 Z28
Engine: LB9
Transmission: auto
Re: I replced my LO3 ECM with one from a 4.3 sonoma
When you reset the batt, did you also happen to clean corrosion off the batt and/or off batt cables? I know mine is really picky about clean connections. If you did clean corrosion off, that may have been your problem from the start.
Old Dec 19, 2004 | 06:58 PM
tanager11's Avatar
Car: 91 Z28 Vert
Transmission: TKO
Axle/Gears: 3.55 10-bolt
Gnarley...if you want to test another one out....to help diagnose...I live in the "sauga...so just south of you....I have no problems doing so.
Dave
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
thunder57
Nov 7, 2015 02:28 PM
Jlanz55
Sep 29, 2015 08:55 AM
efiguy
Sep 27, 2015 01:30 PM
