350 tbi off of ebay that im about to buy
Old Dec 19, 2004 | 12:55 AM
91NiteRida''s Avatar
Car: 1991 Camaro
http://cgi.ebay.com/ebaymotors/ws/eB...941083819&rd=1
What does everyone think of this engine?I might buy it after the new year to start off my year right =)...If or should I say when i do buy it,ill be adding a LT1 cam,1.6 roller rockers,headers,true dual exhaust and a 350 TB...What does everyone think???
Old Dec 19, 2004 | 03:06 AM
BronYrAur's Avatar
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
I don't think it's worth it, the heads or swirl port heads. Terrible heads. You can get a better motor for that price I'm sure. Look for something with better heads or a shortblock and put your own heads on there.
Old Dec 19, 2004 | 03:12 AM
Car: 1991 Camaro
ahhh i see....one big thing is that i want to keep my tbi setup on there...so i know it prohibits a lot of my options....I might just convert to carb and call it good but i dont want to lose my MPG
Old Dec 19, 2004 | 03:14 AM
BronYrAur's Avatar
Engine: 305 TBI
How does keeping TBI prohibit any options?
Old Dec 19, 2004 | 03:17 AM
Car: 1991 Camaro
well its a lot easier to make hp with a carb engine compared to a tbi isnt it? or am i trippin?
Old Dec 19, 2004 | 11:01 AM
86z/92rs's Avatar
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
That engine you are looking at has the hydro cam. You will need to do some work if you plan on using roller cam and lifters.
Old Dec 19, 2004 | 12:19 PM
Gunny Highway's Avatar
Car: 91 RS
Engine: 350 TBI
Yes you're trippin. The only thing easier about a carb motor is tuning. But equal HP levels can be obtained as long as everything else is equal.
Look here:
http://www.goautocenter.com/engines.htm
I went with the 300 HP TPI motor w/ the optional TBI cam (it's a Crane grind) and Trick Flow Aluminum heads, but whatever fits your budget should work.
Maybe it's just me, but with a big ticket item like that, I would want some kind of warrenty.
Old Dec 19, 2004 | 12:33 PM
JPrevost's Avatar
Car: 91 Red Sled
I'm not going to comment on what you should do with your money but JFYI, that engine isn't a roller block. So if you want to slide a lt1 cam in there you'll need the $$$ retro roller lifters.
Old Dec 19, 2004 | 12:40 PM
Car: 1991 Camaro
thanks for all the info fella's...ill just look for a roller short block
MustangBeater20
Oct 29, 2022 09:20 PM
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
evilstuie
Feb 28, 2016 03:33 PM
MENINBLK
Aug 5, 2015 11:58 PM
