idle adjustment
Car: Bitchin' 92 RS
idle adjustment
hey guys, thanks for stopping in.
My 92 RS is idling a little high, and I was wondering how to adjust it, not looked very close, but i'm used to carbs. Thanks for the help,
Kyle
Kyle
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: idle adjustment
Kyle
Kyle
Car: 1991 Chevy Camaro
Engine: 305 TBI
Where exactly is it idling at, 1000 RPM, 1500 RPM, etc.? Just asking because it is not uncommon for the stock tachometer in these cars to go bad and read too high. Mine does it, along with countless others.
Car: Bitchin' 92 RS
I can tel it is idling to high by the sound of the engine, the tach is off a v6, so its way off, but by ear, it sounds close to 1700-2000. thanks
Kyle
Kyle
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
if one of the pins of the IAC gets fubared, it will cause it to idle really high. But a vacume leak would be the where I would start looking.
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
My take away here is that the EFI is responsible for the idle. Vacuum leaks or troubled IAC is likely the cause if the car idles high at operating temperature.
Is that accurate?
Sincerely,
Master of the Obvious
Is that accurate?
Sincerely,
Car: Bitchin' 92 RS
I think I have a vacuum leak, like you guys said, one of my hardlines is broke by the vacuum canister.
thanks for all your help! Kyle
