Hypertech streetrunner now my92 305 shuts down at 110mph
Old Dec 16, 2004 | 11:31 PM
clusterhead's Avatar
Car: 92 camero RS
Transmission: 4 speed od automatic
I am new to this site, and also to camaros, but i love both.
i have never had so much fun driveing around town. in fact its the first time in my life that any one has yelled out, nice ride man burn im up. any way i have a lo3 305, i put a dyno max exahst, on it because it was kind of hard to fit duel exhast, becaus of the clrerance between the traction bar and the drive shaft. but i did notice the power diffrance right away, and it sound cool to. so i put in a hypertech, street runner power chip.now
my question is, can i program this chip? and can i use my home pc? it wants to shut down my car at 110 mph, and i have lot's left, im only at 30000 rpm. i just want to haul some *** with what i have.
thanks unclu vern the clusterhead
keep the peac and kill terrorists
Old Dec 16, 2004 | 11:36 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
man bro why would you want to go so fast man. did you know if you get caught going over 100 MPh your car is consider a deadly weapon.
Old Dec 17, 2004 | 12:06 AM
RebelRacer's Avatar
Car: Bitchin' 92 RS
cause its fun to go that fast and if your smart, you don't get caught. I have the same problem, there is a mod you can do, its in the tech articles on this site, check it out.
Kyle
Old Dec 17, 2004 | 12:16 AM
nidyanazo's Avatar
Car: Gutted 92' RS TRACK ONLY / '86 Mustang gt 'vert / 1982 Yamiaha xs400 Cafe Racer
Engine: L03; TBI is IT! / 5.0HO (306) SFI / 400cc air cooled twin
Transmission: 700-r4 / WCT5/ 6-speed close ratio
https://www.thirdgen.org/newdesign/tech/unlimited.shtml
blamo
Old Dec 17, 2004 | 12:35 AM
azvolfan's Avatar
Car: currently thirdgenless!!!
Your computer is shutting off fuel to the injectors. That's what is happening. It's built into the stock computer chip. It's called a speed limiter and the Hypertech chip probably also has it on there.
Old Dec 17, 2004 | 06:22 AM
Red25thRS's Avatar
Car: 1992 camaro rs
Engine: 305 TBI
aftermarket chips really are not that great...the only reason i still use my jet stage 2 is becuz it took out the speed limiter...so i didnt have to rig anything to cut it out....other than that i cant tell a diff with it in there...hell it probly makes my car run a lil worse for all i know
Old Dec 17, 2004 | 11:46 AM
RebelRacer's Avatar
Car: Bitchin' 92 RS
my hypertech gave me some throttle response, changes shift points, and it has more pull all around the powerband.
Kyle
Old Dec 17, 2004 | 03:41 PM
BronYrAur's Avatar
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
Your shift points are not controlled by the computer. The only thing the computer controls with relation to your trans is the Torque converter lockup. The gains you're going to feel are just feeling, I bet it runs no faster at the track if you tried it. They set those chips up by just throwing in more fuel or timing somewhere so it might kick a little harder in some spots and feel like its faster but it realy isn't any faster.
Old Dec 17, 2004 | 04:12 PM
JPrevost's Avatar
Car: 91 Red Sled
They can be faster. Just not $130 faster than stock. Like a tenth and 1mph if you're on a cold motor. They just through in a little extra timing here and there and change things around, like you said, mostly just feeling . Poor suckers.
Old Dec 17, 2004 | 05:37 PM
RebelRacer's Avatar
Car: Bitchin' 92 RS
no, they programed it to my mods, so it would mate up better than the stcok computer, it wasn't just picked off the shelf, mine was programmed.
kyle
Old Dec 18, 2004 | 02:29 AM
nsimmons's Avatar
Did they dyno tune your car? if not they didnt tune it to your mods. They guessed.
Old Dec 18, 2004 | 06:29 AM
JPrevost's Avatar
Car: 91 Red Sled
kyle
Really! I don't believe you after the statement about the shift points.
Oh, and JFYI, all chips are programmed.
Old Dec 18, 2004 | 10:28 AM
Red25thRS's Avatar
Car: 1992 camaro rs
Engine: 305 TBI
dude throw that chip away...go outside and advance ur timing by like 4 degrees...youll feel alot more than that chip and its free...u cant change the shift points on our car with a chip...and if they did custom tune it like u said...it was just a guess.....every 305 is gonna run a little different soo u dont have like a general thing to start with to tune...if they guessed by ur mods ur car probly runs worse
Old Dec 22, 2004 | 10:50 PM
RebelRacer's Avatar
Car: Bitchin' 92 RS
ok, you guys are getting me wrong, by changing shift points, I mean the car shifts at a different MPH than before, I'm not sure if its a different rpm, but it shifts at different speeds, not real significant differences, but different.
"dude throw that chip away...go outside and advance ur timing by like 4 degrees..."
Already did this.
I'm not trying to cause a big argument, I was just doing like the rest of us and stating my oppinion.
Kyle
Old Dec 23, 2004 | 10:48 PM
r90camarors's Avatar
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
It's not so much people are trying to offend you, it's that we are offended that companies charge $130 for a POS chip,
Jon is right, the chip will make a difference, sometimes for the better, sometimes for the worse. I have a Hypercrap "stage 2" chip in my 305 because it may be netting me an extra tenth if I am lucky. However, the only reason I have it is because I bought it 3 years ago for my 1st camaro project and did not know any better at the time
Your mph is directly related to your rpms and will only change if you change rear end gearing, tire size, or tranny gearing. Or if your tranny is slipping. Nothing in the chip will effect it or shift points however. It is either wishful thinking (don't feel bad), or maybe your kickdown cable needs adjustment.
angel2794
Sep 8, 2015 06:22 PM
Matt86IROC
Sep 7, 2015 06:30 PM
greenyone
Sep 2, 2015 03:39 PM
NBrehm
Aug 25, 2015 11:49 PM
Fronzizzle
Aug 9, 2015 01:15 PM
