trouble starting my camaro
Car: 1990 Camaro RS
Engine: 5.0 liter TBI
Transmission: Borg Warner T-5
i tried starting my camaro today and it wouldnt start, i heard the fuel pump kick in. i tried again this time holding the gas down and the car started. it was flooded and and wouldnt run unless i held the gas down a little. what could my problem be? the car has been setting due to winter weather. but i have been starting the twice a week to make sure the engine doesnt ruin. my car is a tbi car.
I can't tell you whats wrong my but my friends rs did the same thing. I think i just reset the computer by unhooking the battery. After i let it sit for a day of course. It ran like nothing ever happend to it. Good luck
Car: 1991 Chevy Camaro
Engine: 305 TBI
You said it wouldn't start, but in what way? I'm assuming that the engine was turning over, but wouldn't catch and run, right?
Did the "check engine light" come on at all? How long has it been since the regular tune-up parts have been replaced (cap, rotor, spark plugs, spark plug wires, O2 sensor, fuel filter)? I would suggest getting someone else to try cranking the engine while you watch the TBI unit and watching the spray pattern of the injectors, sometimes if they sit for long enough they can get clogged a little bit.
Car: 1990 Camaro RS
yes the SES light came on. also the car started. but i had to hold the gas in while i cranked the motor. when it started it was spitting kinda like i wasnt getting enuff spark to fire the motor.
my mom has a 2000 ford explorer that does the same thing. and she was told that it may be her tps, so im thinking that maybe whats wrong. im gonna check it out today. it got dark on me last night so i didnt fool with it, i had a spark plug tester i guess i could run it from my coil to the distributor to see whats happening. and i will scan it for codes to. ill keep you guys posted!
Car: 1991 Camaro RS
Engine: 305 TBI
Transmission: WCT5
check your MAP sensor, TPS sensor, and check for vacume leaks... a lot of the time a vacume line or capilary(sp) will be busted and you cant see and it will prohibit your car from starting
Car: 1990 Camaro RS
i replaced the coolant sensor and the car starts and idles fine. it looked like old rusty coolant down in were the sensor was. so i took a tooth brush and stuck it down in the hole and twisted it around. and new coolant started seeping through the nasty stuff.
finally i got it all cleaned out to were the coolant was nice and clean (green) and put the new sensor back in.
backtothe80s
Sep 5, 2015 12:39 AM
92camaroJoe
Aug 13, 2015 06:07 AM
