LTI Cam set
LTI Cam set
THIS ROLLER KIT IS FOR 92-97 350 LT1,INCLUDES:
16 ROLLER LIFTERS,
16 ROCKER ARMS
16 PUSHRODS
16 ROCKER NUTS
16 ROCKER SPACERS
8 KEEPERS
1 SPIDER TRAY
3 SPIDER TRAY BOLTS
1 THRUST PLATE
2 THRUST PLATE BOLTS
1 LT1 CAM
ALL PARTS ARE USED WITH 30K OR LESS
I saw this on the good ole e-bay and was wondering if it was actually worth 250 bucks? cuz if it is, im gunna get it. Well, im gunna get it if it will work with my 1994 LO5. I have 083 cast heads too, not the stock swirlies. Cuz if the lt1 parts dont fit, no point in buying em.
16 ROLLER LIFTERS,
16 ROCKER ARMS
16 PUSHRODS
16 ROCKER NUTS
16 ROCKER SPACERS
8 KEEPERS
1 SPIDER TRAY
3 SPIDER TRAY BOLTS
1 THRUST PLATE
1 LT1 CAM
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I would only buy that kit if you were doing a roller conversion. Assuming your new motor is in good shape you already have those parts and do not need them. You would be swaping out for the same parts you already have. I would just buy a $30 LT1 cam and skip all of that other stuff.
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
Well what kind of car is it out of? Or is it a crate engine? It may very well be a flat tappet motor, I'm just asking.
Car: 88 Firebird
Engine: 350 LO5 TBI
Transmission: 700R4 Vette Servo/Shift
trucks were flat tappet up to 95 or 96 i think. The LO5 in caprice, ect was roller. Ive got the same problem with mine, its from an 88 truck.
Car: '90 RS
Engine: 377 LSX
Originally posted by SchwarzCamaroRS
has anyone confirmed if my engine is a roller cam setup or not? just wondering...
Engine: 305 TBI
That should definitely be a roller motor. They don't specifically say that, but caprices of those years were roller and it has the centerbolt valve covers. You could always look for the casting number on the block too if you wanted to know for absolutely sure.
Car: '90 RS
Engine: 377 LSX
crap, i just wasted money then... oh well.. now i have backup roller lifters!! lol
LTI Cam set
16 ROLLER LIFTERS,
16 ROCKER ARMS
16 PUSHRODS
16 ROCKER NUTS
16 ROCKER SPACERS
8 KEEPERS
1 SPIDER TRAY
3 SPIDER TRAY BOLTS
1 THRUST PLATE
1 LT1 CAM
All buy it all
16 ROLLER LIFTERS,
16 ROCKER ARMS
16 PUSHRODS
16 ROCKER NUTS
16 ROCKER SPACERS
8 KEEPERS
1 SPIDER TRAY
3 SPIDER TRAY BOLTS
1 THRUST PLATE
1 LT1 CAM
All buy it all
well, i need the cam still, haha, but ill probably keep the other stuff around for when i do another build... that guy sells LT1 kits like that ALL THE TIME, he had 4 for sale when i got mine. now i just need some full roller rockers and some new springs and ill be set. aside from the work on my heads... gotta get a die grinder and print out SittingBull 's guide before that adventure gets underway though...
i say do it your self, you'll take pride in knowing you put in the work
i dunno but im sure that it'll be $150 to $250 just a guess?
well charge *** loads now a days, i think they chage 300 bucks just to put a alaneter in my dads work van, thank gosh his wrok pays for it all
.... oh BTW heres some cam specs the lt1 should be in there.... also depends what heads you have and how much lift they can take you can determn your self its all up to you... stock steel rockers suck... not talking about raitos either...
i dunno but im sure that it'll be $150 to $250 just a guess?well charge *** loads now a days, i think they chage 300 bucks just to put a alaneter in my dads work van, thank gosh his wrok pays for it all
aluminum are **** to crack at high lifts, you have the same heads as i do altho im ditching them for heads that well be abile to take more lift , a safe lift should be .460 and the max lift on are 083's are .480
well, either way... the 1.6 are going to be too big, mine is a 94-95 LT1 and with 1.6 rockers it has .480/.491... damn... 1.5's it is... is there any way i can modify them to take more lift? id planned on getting the screw type rocker shafts to replace the pressed ones and of course new springs...
ambainb
Apr 25, 2016 09:21 PM
Mickeyruder
Sep 2, 2015 02:45 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
