New 890cfm Throttle Body by NOS
Old Feb 18, 2005 | 12:58 PM
PizPump's Avatar
Check this out:
http://store.summitracing.com/partde...2&autoview=sku
Looks like a decent upgrade from the Holley! And a nice price as well...
Old Feb 18, 2005 | 02:22 PM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
That thing is huge, 2.25" throttle bores should feed just about anything enough air. Unfortunately your still left with the problem of feeding enough fuel to support the kind of HP that throttle body can feed. I guess you could use the N2O port to feed extra fuel into the engine insead of N20, just have to find a way to make the ecm acount for this extra fuel.
Old Feb 18, 2005 | 02:35 PM
va454ss's Avatar
Car: 90 454SS
Engine: 454 TBI
Transmission: TH400
A pic would be nice.
I've got 2.2" bores; close enough
Old Feb 18, 2005 | 02:46 PM
PizPump's Avatar
Summit isn't shipping until 3/7, so it's probably too new for a pic. Been scouring for something, but haven't had any luck so far...
That should do nicely for a forced induction TBI setup
That price is killer too...I'm tempted to order one right now.
Old Feb 18, 2005 | 03:29 PM
va454ss's Avatar
Car: 90 454SS
Engine: 454 TBI
Transmission: TH400
I reread the descrip; says injectors included
Old Feb 18, 2005 | 04:09 PM
PizPump's Avatar
I'm thinking the price is wrong. $287 with injectors?
That's $100 cheaper than the 502-6, and Holley is the parent company of NOS. Something doesn't quite seem right.
Old Feb 18, 2005 | 04:12 PM
va454ss's Avatar
Car: 90 454SS
Engine: 454 TBI
Transmission: TH400
The price is probably right for a bare TB with no injectors.
Old Feb 18, 2005 | 04:19 PM
PizPump's Avatar
Like you said though, the price includes injectors...
Old Feb 18, 2005 | 08:57 PM
25THRSS's Avatar
http://www.holley.com/HiOctn/ProdLin...NOSCA/nTB.html
It doesn't have nitrous passages. 890 cfm is huge, although if it is flowed at 3 hg then that would be roughly 630 cfm at 1.5 hg. Still more than most would ever need, and you would have the problem of finding an adapter plate to work or boring the manifold out that large. Good find though!
Old Feb 19, 2005 | 11:48 AM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
Anybody remember me? LOL - Remember that I fully designed a 2.25 inch tbi unit in AutoCad Solids? Remember I never built it?
Someone go figure out how high you have to raise the injectors to get the fuel cone to hit right on the blades on that thing.---edit--- ok here's a pic for you... how many pod spacers do you have?
Also - the injector pods injector centers would no longer be correct. (unless the tolerence between the bores is too thin = it will probably crack if torqued down wrong.)
Also - you have to restrict air into the manifold with an adapter plate that doesnt make much sense. Anything bigger than the GM 2" is overkill (unless you have a 454 - above), if you need that much more air and fuel, step over to the 4 bbl holley. - or smarter yet, go to port injected, (not tpi) yank your pod and use your original tbi unit for air control..
O, and everybody better pick one up for weight savings too... it's been lightened by machining out the bottom it says!!!!
Gimmick. Probably a reason there isnt a picture. Even if it is in Summit... it's probably to see if there's a market and how many people call them for one....
Old Feb 19, 2005 | 12:30 PM
SchwarzCamaroRS's Avatar
lol, oh, and hey nic, whats up? maybe the 890cfm at that price isnt too bad considering the 670cfm holley one is over $300 without the injectors/pod, but im pretty sure that Snuf is right. Why would holley sell a TBI unit under the NOS name for a lower price?? gimmick... if they were going to build a hi-performance part to be used by serious modifiers, they would use the holley name, not the Fast and the Furious NOS name...
Old Feb 19, 2005 | 01:41 PM
PizPump's Avatar
Well, it doesn't include TPS or IAC. That keeps cost down. If they are using proprietary injectors, it could work (rather than using Holley's part).
Seems to me this TB might be aimed more at folks building scratch-built TBI systems as opposed to using pre-existing hardware.
Was ready to order one until I saw it uses a Ford style TPS. How assinine. Bleh.
Old Feb 20, 2005 | 12:19 AM
89fastlookinRS's Avatar
Car: 89 Camaro RS
Engine: 305 TBI
I saw a pic of it. Not really an easy mod, it's a 4 barrel. Click on the sub link for throttle bodies on his link above. 4 barrels have been discussed on here before I believe. It would take alot of computer tuning and guessing to get a stock computer to run 4 injectors.
But it's a sweet looking throttle body, maybe a good one to pair up with a custom DFI system.
Oh and it says, excepts any small tps.
Old Feb 20, 2005 | 12:29 AM
the one from the link is a two barrel... the one from the second link was a four.. unless summits site is a lying bastard...
Old Feb 20, 2005 | 12:32 AM
25THRSS's Avatar
The link I posted clearly states it is a 2 barrel.
Old Feb 20, 2005 | 01:11 AM
PizPump's Avatar
From Summit:
NOS-20100NOS $286.69
Estimated Ship Date: 3/10/05
OverviewBrand: Nitrous Oxide Systems (NOS)
Product Line: NOS Nitrous Oxide Throttle Bodies
Throttle Body Style: Throttle body injection, TBI
Airflow Rate (cfm): 890 cfm
Venturi Quantity: 2
Venturi Diameter (mm): 57.15 mm
TPS Sensor Included: No
IAC Motor Included: No
Gaskets Included: Yes
Hardware Included: Yes
Injectors Included: Yes
Throttle Body Material: Billet aluminum
Throttle Body Finish: Natural
Quantity: Sold individually.
Great-flowing throttle bodies for nitrous applications.
Throttle Body, 2-Barrel, 890 cfm, 2.250 in. Bores, Universal, Each
Take the guesswork out of increased engine airflow with these highly effective throttle bodies from NOS. Made for a variety of fuel-injected applications, they're CNC-machined from billet aluminum and feature specially contoured air passages for optimum flow. Underneath, each body is pocket-milled for lightening and they'll accept any small-style TPS sensors
Old Feb 20, 2005 | 01:13 AM
PizPump's Avatar
Is the GM TPS considered "small-style"?
Old Feb 20, 2005 | 04:09 AM
snflupigus's Avatar
when i said step over to 4 bbl - i was saying so under the thought that if you have an engine that needs that much - you can afford the complete holley dfi system - Nobody so far has built a working gm 4bbl setup. And seriously, why would you? If you're making that much power... there are smarter ways to spend your time and money.
Old Feb 20, 2005 | 02:11 PM
PizPump's Avatar
Originally posted by snflupigus
...if you have an engine that needs that much - you can afford the complete holley dfi system -
Sorry to drag this off-topic, but that statement is not necessarily true. Anyone (with enough money) can spend money to do things "the right way". Some of us like to (or can only afford to) push the limits of what can be done on a budget.
This TB seems like the only upgrade (at the production level) to the Holley. And at a reasonable price too...
Old Feb 20, 2005 | 05:53 PM
snflupigus's Avatar
no... it still fits... because you cant outgrow the constraints of the stock throttle body without spending considerable dollars and time upgrading the engine itself...
If you NEED an upgrade from the holley 2" because your engine is starved for air - you've already spent considerable money.
Again, simply put, you're not going to need a 2.25 inch 2bbl tbi unit unless you've already spent thousands... and you've already been tuning on your own, and you've learned & understand fully by your own tuning experience that you now NEED more air than the 2" unit can supply.
Unless you're researched enough to KNOW you need more air...
You dont need a bigger throttle body people!!!!
Old Feb 20, 2005 | 08:34 PM
BMmonteSS's Avatar
Car: 84' Monte
What he said. Two 90 lb/hr injectors are going to be maxed out way before the throttle body becomes a restriction. If your running crazy fuel pressure (in the 30's) you might need a slightly bigger TB, but your getting to the point money wise as well as feasiblility wise to go to another form of injection.
Old Feb 20, 2005 | 11:12 PM
since when is doing things out of necessity the american way? america is the land of excess and even though i believe you, and anyone who knows his a$$ from a hole in the ground does too, there will still be some dumb idiot who will spend the money on a TBI that will provide more air flow than he will ever need... ill stick with my stock TBI with ultimate TBI mods until i actually get to over 350-400hp... new injectors, a VAFPR and good tuning is all you need to bring out the best in TBI... that and getting rid of the top end parts that came with it... regardless, anyone who isnt listening to snuf, should... dont waste your dough, buy yourself some nice shiny stickers and a huge wing... if will do you the same bit of good as that TBI
Old Feb 21, 2005 | 11:30 AM
7Point4's Avatar
Car: 1990 Chevy 454SS
Engine: 454
Transmission: TH400
Just in searching, that part number is available for sale at a lot of sites, and its even listed in NOS's 2004 catalog, but not a picture to be found.
At that price, I probably will try to get one, if its what it says it is.
I read only about 90-94kpa at WOT, and the AFR is what it is supposed to be, so i think my application would benefit from more CFM.
Old Feb 21, 2005 | 05:05 PM
it makes sense for you... @ 7.4L haha, but anyone running a 350 or even a 383 wouldnt have much use for that
Old Feb 22, 2005 | 08:14 PM
snflupigus's Avatar
Jon (jprevost) came out from Jersey last weekend and Bill (azvolfan) and I were able to see him in all his glory tuning Bill's car...
One thing he convinced me of is that the vafpr is not needed when tuning the ecm is understood and it actually makes things more difficult.
Another thing that he confirmed( as I've talked about this for literally years now with many members of the board) is that 2" is as much as anybody really needs with tbi. Air is not the problem on TBI.
I wish he'd post more but I know he's busy. All I can say is that I think most long awaited questions concerning tbi issues will be answered by him thoroughly soon. Jon, want to confirm that?
Old Feb 22, 2005 | 09:04 PM
i havent been on TGO very long, but from what i have heard and seen, Prevost is the man when it comes to TBI... and, from the sounds of things, he knows his **** cuz bill had his car professionally dyno-tuned and Prevost made it better... if he says 2" is more than enough, then damn it, 2" is more than enough... 670cfm is plenty...
Old Feb 23, 2005 | 12:08 PM
90RS305's Avatar
Car: 96 Silverado/99 Suburban
Engine: 700 cubic inches of 'Muican Awesome
Transmission: 4L80/4L60
Axle/Gears: Chunky/Clunky
Thats why we don't remember you Nic, you're all talk! LOL, j/k...
Snuf hit the nail right on the head.....then continued to pound it in till it was sticking out the other side of the board. Stuffing more air into your car isn't going to do you didly squat unless the engine can acutally USE the extra air. And, just like Snuf said, unless you've already spent half your 401K on your 305, it won't do you any good. Listen to the experts here, they know what they are talking about
Bruce (90RS305)
Old Feb 23, 2005 | 12:28 PM
JPrevost's Avatar
Car: 91 Red Sled
There isn't really any reason for me to reply. You guys are all coming to the right conclusions about TBi and it's restrictions. Fuel, yes, air, not nearly as much. Like Bruce said, what good is the extra air if you don't have the fuel to burn it? Fuel is where your power is, you need enough fuel AND air to make increases in power, not one or the other.
My proof that 2" is plenty of air is all over GM. Yes you want all the air you can get but focus on where TBI hurts... code and fuel.
Thanks guys for the plug .
There are SO many ways to get the code to work, some are easier than others and some ways will save you time now but cost you later when things start getting really close. That's where experience comes into play. I wish I had webspace, if I did I'd have a step by step tutorial on how to tune TBI code. Bruce's 7747 programming 101 is a tad out-dated but still a great base. Anybody got some free webspace they want to give me that doesn't have banners?
Old Feb 23, 2005 | 01:21 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
Jon,
Email me -- dewey316 at gmail.com
or hit me up on one of the messaging service, all my info is listed on my profile here.
Old Feb 23, 2005 | 03:16 PM
90RS305's Avatar
Originally posted by JPrevost
...Bruce's 7747 programming 101 is a tad out-dated but still a great base...
Old Feb 23, 2005 | 04:07 PM
7Point4's Avatar
Engine: 454
Transmission: TH400
well..
Just talked to NOS, and summits listing is wrong.
It is a 'air' throttle body only, no injectors, no place for injectors, etc.
It is meant for folks that are building thier own intakes. Thats what the guy from holley said. (NOS).
Was fodder for the board though.
Old Feb 23, 2005 | 08:41 PM
snflupigus's Avatar
Bruce's 7747 = Grumpy.
I'll buy more webspace with tripod if you want... it's cheap.
Old Feb 24, 2005 | 10:26 AM
90RS305's Avatar
Ohh duh, I knew that...
1992 Trans Am
May 10, 2023 07:19 PM
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
