Edlebrock performer Intake
Old Feb 22, 2005 | 07:51 PM
RebelRacer's Avatar
Car: Bitchin' 92 RS
Anyone try this Intake? what kind of performance gains did you see?
heres the link http://www.jegs.com/cgi-bin/ncommerc...98&prmenbr=361
its almost at the bottom.
thanks,
Kyle
Old Feb 22, 2005 | 07:54 PM
sunset92's Avatar
Car: sunset orange 92
Engine: 5.0
Transmission: t-5
i have the performer rpm it makes more power and trq than the plain performer.
but it may not fit under your hood unless you use a drop base cleaner, i have the ss hood
Old Feb 22, 2005 | 08:44 PM
My91RSCamaro's Avatar
Car: 1991 Camaro.
Engine: 305 TBI
I just installed this intake on my 91RS. First of all you have to hone out the EGR port to make your stock EGR valve work.
If you have S-belts and A/C you have to drill and tap the intake for an accessory bracket.
My mods are , OPEN Element K&N with Xtream top, Hypertech stage 2 chip, high flow cat, and a flowmaster dual chamber muffler.
I noticed a good gain after 3000rpm. and the exhaust note on acceleration sounds alot better. the engine revs easier. but there seams to be a slight loss on the bottom end. Maybe its another problem, not just the in intake. I think the chip wasnt worth jack. I want to have Turbo city burn me a chip. those guys have TBI DOWN!!!!!!
Old Feb 22, 2005 | 09:00 PM
lonniep01's Avatar
Car: 88" CAMARO
Engine: 305 TBI
what was the part number on the intake you used.i am wanting to put one on my car.how do i get ahold of turbo city for a chip.
Old Feb 22, 2005 | 09:07 PM
sunset92's Avatar
Engine: 5.0
Transmission: t-5
i did not have any problems with accessory brackets on my rpm, also mine has no egr and i have no smog pump either.
Old Feb 22, 2005 | 11:48 PM
RebelRacer's Avatar
Car: Bitchin' 92 RS
will the non-egr intake work with egr heads?
thanks,
BTW, with the RPM, where did your power come in, low, mid or high range, and what rpms is it turning?
what type of gains did you see?
thanks, Kyle
Old Feb 23, 2005 | 08:13 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Don't bother with any over the counter chip. They do know their stuff but cannot know what your car needs without looking at a live data streem via WD02 and datalogging. It is like mail order surgery. Sure the Doc is a pro but he can't do anything until he has you on the table.
Old Feb 23, 2005 | 02:16 PM
RebelRacer's Avatar
Car: Bitchin' 92 RS
thaqnks for the help, I think i'm gonna go with the regular performer, what type problems will I run into doing this swap?
Also, I have a Helix TB spacer, will this still work with the performer?
Kyle
Old Feb 23, 2005 | 08:46 PM
sunset92's Avatar
Engine: 5.0
Transmission: t-5
the rpm adds a whole lot more power than just the plain performer. and i intalled mine at the exact same time i installed my lt1 cam so it made huge gaine throughout the rpm range. also i think the rpm makes power from 1500 to 6500 rpm's
and i have a 92 model with regular heads and i am noit using the egr and i have had no problems as of yet, and i have had this combo for over 2 years!, but i nned to start burning my own chips!
Old Feb 25, 2005 | 07:36 AM
RebelRacer's Avatar
Car: Bitchin' 92 RS
I don't really want to have to use an adapter, I just put a TB spacer, and I'm afraid If I have an adapter, hood clearnce will be an issuse.
Any solution to this?
Kyle
Old Feb 25, 2005 | 06:26 PM
sunset92's Avatar
Engine: 5.0
Transmission: t-5
well the performer is a carb intake as well or do you mean the performer tbi intake? also if you use a drop base cleaner and a 2 or 2.5" filter you should be ok with the performer rpm
Old Feb 27, 2005 | 07:34 PM
RebelRacer's Avatar
Car: Bitchin' 92 RS
I want the performer RPM, but I got a 3 inch K&N with the drop, and 1inch throttle body spacer, will the RPM work with an adapter? how close will I be to the hood, is there any bracing under the insulation that can be cut for room?
Kyle
Old Feb 27, 2005 | 08:53 PM
sunset92's Avatar
Engine: 5.0
Transmission: t-5
you could get the ss hood like me... it looks great!
Old Feb 27, 2005 | 10:39 PM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
My experience with the RPM intake shows that it's tight with just an adapter. The thinner you can get the better. My bro is running the GM vorte intake with just a carb and he has to run a 2" filter in his drop base to clear the hood. The RPM is taller than the GM intake, but a TB is shorter than a carb, but again the adapter plate makes up for most of this.
Come to think of it I don't know of any one with an actuall Performer RPM and a stock hood. If you have it post up and let us know.
Old Feb 28, 2005 | 02:43 PM
RebelRacer's Avatar
Car: Bitchin' 92 RS
Ok, I'll let you know IF i get one, I might have to cut out the insulation and bracing, Might also need 2in filter.
theshackle
Mar 5, 2017 06:37 PM
z28guy134
Sep 1, 2015 11:50 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
86IROC112
Aug 17, 2015 02:00 PM
