TBI project.
Old Mar 14, 2005 | 12:36 PM
charliemccraney's Avatar
Car: 1988 Firebird Formula
Engine: 305 (LO3)
Transmission: 5 spd manual
TBI project.
Hello everyone,
I am in the middle of adding a Vacuum adjustable Fuel pressure regulator, 1" Throttle body spacer and injector spacer.
I want to make new fuel lines so that I don't have to tweek the original ones. Are there any adapters available to change from the stock fitting to a 45* flare fitting or a tool that can make the factory "flare," whatever it is called? I've done a search on this and have found nothing yet.
Thanks.
Old Mar 14, 2005 | 01:05 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
You can convert to stainless steel brake lines which give you more flexability and overall ease of use. YOU may want to vary your wrod choice when searching. Alos, search under z28boy. I belive he has a parts run down on his site.
Old Mar 14, 2005 | 02:22 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
Z28boys write-up is good. I had some problems finding a couple of the parts he mentioned. When I get a chance, I'll grab part #'s and pictures of mine.
Old Mar 14, 2005 | 02:36 PM
Benm109's Avatar
Car: 1991 Chevy Camaro
Engine: 305 TBI
Here's Z28 Boy's website with all the pictures, part numbers, and info: http://z28boy.cz28.com/mods-fuellines.htm
Old Mar 14, 2005 | 03:25 PM
Ronny's Avatar
lookat aeroquip "push-fit" flex line with push-fit fittings. come in all sizes (6 AN) and angles. you avoid the tubing bending. reusable as well.
Old Mar 14, 2005 | 04:29 PM
Engine: 305 (LO3)
Thanks for the help. I'll take a look z28boys site and the push fit lines.
Old Mar 15, 2005 | 07:55 AM
Engine: 305 (LO3)
You know, I have been to z28 boy's site before. I just never got to that article. That should do the trick. With some aluminum tubing I should be able to keep a stock look. Most of the fittings will be hidden anyway.
I kind of wish that I had found that article sooner. I bought one of the fuel pressure gauge adapters from CFM-tech, which is a great part, but I will have to mount the gauge remotely because it will not fit under my air cleaner because I have modified it so that it will fit without that spacer ring thingy. With the AN fittings I can mount it right to the fitting, similar to the way that z28boy mounted his.
Thanks for the link. I will start looking for all of the pieces soon.
Old Mar 16, 2005 | 02:11 PM
Engine: 305 (LO3)
I just found a tool that can make the factory flares. Check it out if you want. It is only $425.00.
http://www.inlinetube.com/tools.htm
I think I will stick with the AN fittings for now but it is good to know that there is something available.
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
David Frans
Oct 31, 2015 08:12 PM
skinny z
Oct 5, 2015 06:23 PM
Gordonr1973
Sep 29, 2015 11:59 AM
