Unknown Sensor
Old Apr 28, 2005 | 07:29 PM
Rossdaddy63's Avatar
Car: 1991 RS
Engine: 305 TBI
Unknown Sensor
I have a 1991 RS. The other day I was taking off my passenger side exhaust manifold. While I was taking it off I realized there was a broken sensor that was inbetween the back 2 bolts. I want to replace this sensor, but have no idea what it is. Does anyone know what this sensor possibly could be?
Old Apr 28, 2005 | 07:32 PM
Benm109's Avatar
Car: 1991 Chevy Camaro
Engine: 305 TBI
Sounds like the coolant fan switch to me.
Old Apr 28, 2005 | 07:39 PM
Car: 1991 RS
Engine: 305 TBI
Ok, thanks, I am going to try to get a picture of it tomorrow to post. It had a plastic housing that was shattered.
Old Apr 28, 2005 | 07:54 PM
Benm109's Avatar
Engine: 305 TBI
Did it look like this?
Old Apr 28, 2005 | 08:04 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Benm is right on. Everyone detroys this sensor when they remove the manifolds. I annihilated mine doing the same thing
Old Apr 29, 2005 | 10:54 AM
Cadillac's Avatar
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
I've learned a lot about this part since I've been on TGO. You can get an upgrade on this switch if you need it that will make your fan come on at cooler than stock temps and thereby enhancing your ability to cool the engine. On top of a lower than stock stat, this has greatly improved my engine's operating temp.
Here is a good reference thread (with pics!)
Old Apr 29, 2005 | 12:00 PM
Ronny's Avatar
i got mine from hypertech.
Old Apr 30, 2005 | 10:14 AM
Car: 1991 RS
Engine: 305 TBI
This is a picture of the wire. It had a plastic housing, but thats shattered now. The second picture is of what that wire plugs into. What do you guys think it is?
Old Apr 30, 2005 | 10:15 AM
Car: 1991 RS
Engine: 305 TBI
where the arrow is pointing
Old Apr 30, 2005 | 10:23 AM
Benm109's Avatar
Engine: 305 TBI
Yep, it's definitely the fan switch. But, as you know, both the fan switch and the connector for it are broken.
Old Apr 30, 2005 | 10:30 AM
Car: 1991 RS
Engine: 305 TBI
OK, thank you, so i will need the new connector and the switch. Where could I get one? Which kind do you recommend? And how do I put the connector back on, solder it?
Old Apr 30, 2005 | 06:53 PM
Car: 1991 RS
Engine: 305 TBI
Is there any possible way it could be my knock sensor?
Old Apr 30, 2005 | 08:02 PM
vjo90RS8's Avatar
Car: 2002 Z28
no, the knock sensor is farther down....i am also another that has broken that switch when installing headers.
Old Apr 30, 2005 | 11:03 PM
Car: 1991 RS
Engine: 305 TBI
Well in this pic it looks pretty far down. Isn't it right above the starter? Wouldn't it be the knock sensor thats down that far?
Old May 1, 2005 | 12:51 PM
Benm109's Avatar
Engine: 305 TBI
No, it's definitely the fan switch. The knock sensor is located in the engine block right above the oil pan. Here's what the knock sensor looks like:
As for a new fan switch and connector, you can get a stock replacement fan switch at any auto parts store, but it turns the fan on somewhere above 230*. Both Jet and Hypertech make cooler temp. fan switches for our cars (check out Summit Racing or Jegs for them), but they cost over $40.
But, you can get the same fan switch for $13 here, part number 609-106. And if you buy the "conversion harness", it will come with the connector you need: http://www.madvet.com/shop?frame=1.138.944
If you just want a connector, try here:
http://www.turbocity.com/product_inf...products_id=88
http://www.rosesandwrenches.com/conn...tors&UID=10037
I know in the 2 above links they are referred to as knock sensor connectors, but it will work. The connector for the knock sensor and the fan switch are the same kind.
HoosierinWA
Oct 7, 2015 10:15 AM
aaron7
Sep 30, 2015 09:15 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
dusterbd
Sep 29, 2015 08:40 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
